VM30's on an R5, throttle options?
Started by idr5c, August 09, 2020, 11:27:09 AM
idr5c
I've run into a snag on my racebike prep, hoping the brain trust can :help:
I'm switching to a ported R5 top end and VM30's (large frame type) and I realized last night that the stock throttle setup doesn't seem to have the needed adjustment/travel to pull these carbs. I'm going to disassemble the junction block today and see if I can get more travel.
Can the stock R5 throttle setup work with these carbs? If not, I'll need to convince John to 2-day ship one of these   :dawg:
https://www.economycycle.com/shop/yamaha-rz-350/frame-related-yamaha-rz-350/cables-yamaha-rz-350/vm30-38-throttle-and-cable-kit-not-for-tm/
Stephen Phillips
WMRRA #494
http://www.wmrra.com
Chuck made my R5 throttle work with TM32s, honestly I never asked how he did it.
Sorry that's all I got
bitzz
I once got a DNS because I was putzing with that cable splitter. ONCE.
Now all my twins have a Tomiselli Daytona throttle  with THREE cables. One cable is a spare that never gets lost
Economy Cycle John
Quote from: idr5c on August 09, 2020, 11:27:09 AM
I do have a cable that will work with the stock throttle with or without the pump, not on the website, just give us a call.
idr5c
Thanks John, I'll call today to get the right cables on order.
For this weekend I figured out that I could use a RD350 junction block and cables, but then they were too long so I machined a spacer to take up the slack at the junction end. Not the most elegant solution but it will work until the proper cables arrive.
Thanks everyone! :clap:
Stephen Phillips
WMRRA #494
I had to fab my own throttle cable for my OKO 28mm carbs. I just used some spare cables and soldered the ends. It took forever because I had to measure twice and cut once multiple times to make it perfect but I am so glad that I did it because of stock vm28 were way too loose and it messed my 3 way split tension.
