What happens when you throw a Hayabusa engine in a tiny Fiat 500?
Generally the Hayabusa blows up because they don't scavenge well under lateral loads. It takes quite a bit of trickery to get it all going.
Must be an absolute blast to drive.
Check out this guy. Two R1 motors in a mini
https://www.thedrive.com/news/38223/this-incredible-340-hp-classic-mini-has-two-yamaha-r1-engines-in-the-back (https://www.thedrive.com/news/38223/this-incredible-340-hp-classic-mini-has-two-yamaha-r1-engines-in-the-back)
There was a factory built Mini rally car with two standard Mini engine/trans, one in the front, one in the back. You had to shift both transmissions separately. There's a video out there on a gravel stage from in the car. It was pretty amazing, the driver was a famous Fin as I recall, but suffice it to say he was quite busy getting the thing through the stage.
Quote from: sav0r on October 27, 2021, 02:23:03 PM
I have seen something similar at a mini show in England that I went to Guy had a mini wit a R1 motor in the front and another in the back. It was not finished yet though
Local boys @scooterswapshop put a 'Busa motor in a JDM Kei truck.
https://www.youtube.com/results?search_query=scooterswapshop+kei
