Rd400 main axle
Started by RDSingh, June 19, 2020, 03:14:40 PM
RDSingh
Guys, I have started to rebuild another rd400 motor. So started with the transmission first. Disassembled the main axle, found this. Is it normal???
Alain2
It got hot. I have seen worse, a gear was friction welded on the shaft!  :eek:
Yamaha 179
I have replacement gears and shafts if you need some.
Lyn Garland
RDSingh
Quote from: Yamaha 179 on June 19, 2020, 04:46:25 PM
Lyn Garland
thats great, looks like i might need some parts. let me check the condition of drive axle, will pm you.
Every RD that gets an engine rebuild in my shop, ALWAYS get the shafts stripped down...RD's will gall the shafts and gears with run only 400-500 cc down on oil every time...and we all know when RD's are old they leak. Very common problem.
