For a CDI ignition can we use an HT coil from any CDI bike ? or do we need to check something ?
should be ok. Ive swapped them from model to model. just verify values match whatever the cdi needs. usually, the coils are under 1ohm reistance.
Thank you
Any good universal coil suggestions
banshee coils are common and usually fairly cheap
2 single output coils or one dual output coil (banshee) is preferable ?
2 lead typically. what cdi is it?
its an Indian CDI ignition kit similar to the Chinnoy ignition kit for RD. Has a pulsar coil on the stator which triggers the spark. Similar to the vintage Suzuki 2T igny derived
The Vape coils are pretty good as well. Economy has them.
yup.
Quote from: 2t Fan on July 21, 2021, 05:15:41 AM
Thank you
I've used a variety of them, just make sure they have a similar resistance to whatever is used.
