Just...wow. Clearly not mine:
https://www.facebook.com/share/15x3ccoPi8Aqk8Yy/?mibextid=gVQsCx (https://www.facebook.com/share/15x3ccoPi8Aqk8Yy/?mibextid=gVQsCx)
moped? :umm:
not sure that ignition key is in the best location. Definitely needs some work. I would let someone else test it out first before taking that thing for a spin.
its def different. i dont have it... but it def needs some attention
I'm also intrigued by the dangling ignition switch, as well as the master cylinder on the left bar...hydraulic clutch conversion? I wonder if that disc brake could overwhelm the design parameters of the front suspension linkage.
Something sketchy with those rear shock top mounts
That one has "widowmaker" on it for sure! :help:
