The 2-Stroke Garage => Turning Wrenches => Topic started by: Greaser Greg on November 26, 2019, 03:33:02 PM
Title: Ugly case
Post by: Greaser Greg on November 26, 2019, 03:33:02 PM
Acquired this as part of a deal. Does the missing portion compromise the strength enough to make it useless?
Title: Re: Ugly case
Post by: quocle603 on December 02, 2019, 01:35:04 PM
I'd vapor blast and run it.
Post by: Jspooner on December 02, 2019, 01:47:07 PM
I would either run a spacer on the bolt or run a short bolt on each side. I would be afraid of stressing the cases in that area otherwise.
Post by: m in sc on December 02, 2019, 01:54:19 PM
if you use it, get in there and take the sharp edges off (this helps it not crack) and spend some time on it making it look good with a die grinder , flap wheel, and dyna file if you have access, will be worth it. but as Joe says, i'd run 2 separate bolts. ( i do that anyway)  :twocents:
Post by: Greaser Greg on December 02, 2019, 04:48:50 PM
 :metal:
