Building my sons bike he wants to run SS lines and went to both them up last night, I discovered I had the wrong banjo bolt (should be 10x1.0 for caliper), and I found in th tech section that I need to remove the flare or olive fitting inside the caliper to allow room for the banjo bolt.
Question is, how do I remove that fitting inside the caliper? I may be as easy as pulling on it, but figured I'd ask before I make more work for myself.
screw a wood screw just into the filling and use a pliers to pull it out. They come out quite easily.
Quote from: rodneya on January 23, 2020, 10:04:04 AM
Thanks! I was thinking along those lines, but wanted to make sure I wasn't off base.
It came out with a wood screw, but it definitely didn't;t come out easy!
