The 2-Stroke Garage => General Chatter => Topic started by: oxford on May 28, 2023, 11:01:38 AM
Title: Lets build some chambers
Post by: oxford on May 28, 2023, 11:01:38 AM
(https://i.imgur.com/5OpeqzK.jpg)
(https://i.imgur.com/0pUpbXb.jpg)
(https://i.imgur.com/CU1k0Ml.jpg)
(https://i.imgur.com/zwpObHB.jpg)
(https://i.imgur.com/YiV5WuQ.jpg)
(https://i.imgur.com/fW5gCJy.jpg)
(https://i.imgur.com/YMt7gf8.jpg)
(https://i.imgur.com/RVYcfAK.jpg)
Title: Re: Let’s build some chambers
Post by: oxford on May 28, 2023, 11:02:18 AM
(https://i.imgur.com/qPYcDU0.jpg)
(https://i.imgur.com/dmdM5pr.jpg)
(https://i.imgur.com/5x1pzzq.jpg)
(https://i.imgur.com/NmGukkw.jpg)
(https://i.imgur.com/UNC3VRl.jpg)
(https://i.imgur.com/KQHvYvZ.jpg)
(https://i.imgur.com/61ATDEX.jpg)
(https://i.imgur.com/EoaQ48I.jpg)
Post by: oxford on May 28, 2023, 11:03:07 AM
(https://i.imgur.com/qHoFUZz.jpg)
(https://i.imgur.com/lEhVyxU.jpg)
(https://i.imgur.com/brOFIUR.jpg)
(https://i.imgur.com/0Zn1hjc.jpg)
(https://i.imgur.com/1gyqctX.jpg)
(https://i.imgur.com/fkWtYK0.jpg)
(https://i.imgur.com/OCrsbiv.jpg)
(https://i.imgur.com/LTuKRoX.jpg)
(https://i.imgur.com/A7ZerqQ.jpg)
Post by: oxford on May 28, 2023, 11:03:49 AM
(https://i.imgur.com/xOpdBSl.jpg)
(https://i.imgur.com/wLKA1eL.jpg)
(https://i.imgur.com/XJxtG6L.jpg)
(https://i.imgur.com/AOEt6BB.jpg)
(https://i.imgur.com/2DdfiiU.jpg)
(https://i.imgur.com/4CcLpML.jpg)
(https://i.imgur.com/fRc3KGW.jpg)
(https://i.imgur.com/xnTqQVT.jpg)
(https://i.imgur.com/xR6Vwwm.jpg)
Post by: oxford on May 28, 2023, 11:04:54 AM
(https://i.imgur.com/Xq8gjbz.jpg)
(https://i.imgur.com/Dt1kjDo.jpg)
(https://i.imgur.com/kY0Z87y.jpg)
(https://i.imgur.com/WQ7FenM.jpg)
(https://i.imgur.com/GCnd9bi.jpg)
(https://i.imgur.com/99ws75y.jpg)
Post by: oxford on May 28, 2023, 11:05:51 AM
(https://i.imgur.com/ANafLS2.jpg)
(https://i.imgur.com/17sSd4R.jpg)
Title: Re: Lets build some chambers
Post by: dgorms on May 28, 2023, 11:14:13 AM
Impressive! I'll take a set for my R5.
Post by: LMS on May 28, 2023, 11:51:10 AM
Amazing! :clap:
Post by: Kawtriplefreak on May 28, 2023, 02:33:20 PM
 :righteous:  :righteous:  :righteous:
Post by: m in sc on May 28, 2023, 03:06:41 PM
hell yeah. looks great. where did the cone design come from/get calculated?  the fab looks fantastic. love the hanger bolt method.
Post by: oxford on May 28, 2023, 03:20:54 PM
Quote from: m in sc on May 28, 2023, 03:06:41 PMhell yeah. looks great. where did the cone design come from/get calculated?  the fab looks fantastic. love the hanger bolt method.
Thanks.  They are clones of the Vanguard pipes.  Manifolds and the silencers are mine.
Post by: 85RZwade on May 28, 2023, 03:26:38 PM
So beautiful, thank you for posting this!
Post by: Hawaii-Mike on May 28, 2023, 04:54:58 PM
Oxford! Do you have or are you planning to make anymore VM30 carb adapters?
Post by: oxford on May 28, 2023, 05:02:42 PM
Quote from: Hawaii-Mike on May 28, 2023, 04:54:58 PMOxford! Do you have or are you planning to make anymore VM30 carb adapters?
I don't have anymore and don't really plan on making anymore anytime soon.
Jess bikes took the last couple of sets I had.  I don't know if he has anymore or what he was charging for them.
Post by: The Red Scourge on May 28, 2023, 09:20:26 PM
 :jaw:
Post by: oxford on May 28, 2023, 11:28:59 PM
Quote from: m in sc on May 28, 2023, 03:06:41 PMlove the hanger bolt method.
Thanks.  I came up with this for the JL pipes I had on the bike, and just used the same for these.  The JL's don't look quite as nice on the mounting since it has the big slot on the mounting tab.  It was also a little tricky to get the correct size hole in the slot.
I had originally used a version of this with the grommets and shoulder bolts on a set of WTF pipes for a kawi triple.
Post by: m in sc on May 29, 2023, 08:55:29 AM
im going to steal the threaded insert method/shoulder bolt grommet, for sure down the road.  :toot:
Post by: Striker1423 on May 31, 2023, 09:01:21 AM
I would totally lose my foot pegs and center stand for a set of these!
Post by: Evans Ward on May 31, 2023, 05:06:00 PM
Beautiful craftsmanship! You have such a talent!  :clap:  :olaf:  :thumbs:
Post by: sav0r (CL MotoTech) on June 01, 2023, 11:44:52 AM
The amount of welding on the bendy bit makes me anxious. As in, I can't fathom how long that took.
Post by: m in sc on June 01, 2023, 11:51:26 AM
I have to ask: why the vanguards and not something like specII's? (for example) i didn't think they (vanguards) made good power. the craftsmanship is pretty amazing though, well done indeed.
Post by: oxford on June 01, 2023, 01:08:49 PM
Quote from: m in sc on June 01, 2023, 11:51:26 AMI have to ask: why the vanguards and not something like specII's? (for example) i didn't think they (vanguards) made good power. the craftsmanship is pretty amazing though, well done indeed.
I had the DXF files for them from a long time ago and was looking for something to do over the winter.
I didn't initially make them when I was putting the bike together because I thought they weren't going to look right on a TZ rep and just went with a set of JLs.  After getting them on the bike I don't think they look all that bad.  I do think I have them tucked up higher then the originals were.
As far as power, I think there are still some dyno charts out there from the originals.
Post by: oxford on June 01, 2023, 01:15:26 PM
Quote from: sav0r on June 01, 2023, 11:44:52 AMThe amount of welding on the bendy bit makes me anxious. As in, I can't fathom how long that took.
I think it took more time to get them tacked together than it did to finish weld them out. Finish welding is easy if you did your part up to that point.  Get your welder settings dialed in, mash the pedal, and run it.
Post by: m in sc on June 01, 2023, 02:27:31 PM
i get it, was just curious. maybe they will work better than what i remember they did, but they look fantastic for sure.   :cheerleader:  :patriot:
Post by: Kawtriplefreak on June 01, 2023, 03:04:43 PM
They do look great :thumbs:  :thumbs:
Post by: Dvsrd on August 11, 2023, 03:04:35 AM
Mark,
The dyno sheet on the Vangurd site shown 43 hp with stock porting, and at pretty low revs. A totally stock 350 would not be much over 30 hp on a dyno, I believe. So how much more power would a set of Spec 2 or JL give on stock porting?
Post by: Dvsrd on August 11, 2023, 03:06:22 AM
Quote from: Kawtriplefreak on June 01, 2023, 03:04:43 PMThey do look great :thumbs:  :thumbs:
Agree! I really like how tightly they are tucked under the engine. I really dislike a huge air gap between chambers and engine/ frame.
Post by: Dvsrd on August 11, 2023, 05:22:53 AM
Quote from: oxford on May 28, 2023, 03:20:54 PM
I wonder why the diffuser cone is made from 2 sections? On the pictures both sections appear to have the same angle, and I cannot see any bend either. Just limitations with regards to roller width, or am I missing something here? In any case impressive work!!
Post by: oxford on August 11, 2023, 06:12:30 AM
Quote from: Dvsrd on August 11, 2023, 05:22:53 AM
I wonder why the diffuser cone is made from 2 sections?................................................... Just limitations with regards to roller width, or am I missing something here?
Pretty much this.  I made that 2 pieces, the original files were 1 piece.  My small roller is only 12" wide.  I have a bigger 30" wide one I probably could have got it done on but I figured welding the joint was easier than messing with the full length cone.
Post by: oxford on August 11, 2023, 06:21:51 PM
Anyone on here that does CAD/Solidworks want to work on something together?
I am looking to trade what files I have for these for some touch ups on them.
I am also looking for someone (maybe 2) that wants to do a custom set of pipes. I'll bring the fab and welding.  PM if anyone is interested.
Post by: svgarage on August 13, 2023, 11:27:18 PM
Nice work! Very impressive!  :clap:
