What are the pros and cons of injection vs putting in a block off and running pre-mix? New here! Bought my first rd350!
A pro is the oil pumps are basically bullet proof and cause you not to have to carry around baby bottles of oil when you ride around.
Not too many cons as long as the pump is working.
if the pumps working, and 99% of them are, run it.
to 'put in a blockoff plate' you have to pull the clutch cover, etc. the drive shaft is removed from the back side. :twocents:
I run 2 rds with premix. 1 has a waterpump there now, the other is my lightweight project and ai ran a different crank that wont allow me to run one (thats a looong story).. def NOT practical reasons. however, on my r5, i run it, and its fine. ran the original pump on my old rz as well.
Pros of no oil pump/ oil tank would be some weight savings and there's less to fuss with when it comes to tuning and maintenance.
Pros of pump would include better metering of oil as the pump works off of throttle position- in addition to what others wrote above.
Premix works best for track riding if you want to be the lightest you can be. The pump is great for street riding and works good on the track too. IMHO.
Can u guys suggest where we can find an aftermarket
More modern oil pump. I will purchase that unit for my project
In India almost everyone does premixes
But the pros for a well functioning oil pump definitely make it worth it
the original ones are fine, theres no 'modern replacement'.
youd think with everyone running premix they would be littering the street with unused pumps. :whistle:
I am a big fan of the pump. Even if you can't find a good working one there are plenty of them out there that can be rebuilt.
If you need a pump rebuilt, send it to "arrow" in the UK.
He is the undisputed master of all throngs RD/RZ oil pump related.
You can find him on Norbo's forum and the other RD/RZ forum.
USE THE PUMP!
I bought the bike running off pre-mix. I just left it like that, when I was getting gas at the station. I decided to get 2 gallons which is about 8 fl oz of oil. I thought I had a bottle that was that much and poured the entire thing in, but it was 16 fl oz. I had to ride and around without stopping until I ran out of gas at high rpms (for a strong spark). I decided to put the pump back and never worry again.
Quote from: quocle603 on July 09, 2019, 06:41:05 PM
USE THE PUMP!
Not sure how you mistake 16oz for 8oz. :whoop:
Quote from: Jspooner on July 09, 2019, 07:23:22 PM
Wasn't really thinking...I just had it in an old 2t bottles that I carry around.
Oil pumps are sweet! I like them more than in years past now that I have a handle on setting them up. :celebrate:
The pain is... it can be a lot of work until you get perfect, especially if setting up TM34's. Much longer pull means I have to make custom cables and use aftermarket splitter. :umm:
USE THE PUMP!
That bud light can is exactly what I use to put my oil in. I sanded all the paint off (or most of it) and put it in my tank bag. Works perfect!
