The 2-Stroke Garage => Turning Wrenches => Topic started by: Brad-Man on September 17, 2019, 02:56:12 PM
Title: What size bolt to remove Iggy rotor from crank?
Post by: Brad-Man on September 17, 2019, 02:56:12 PM
Subject line says it all...
Bolt size/thread.
Thanks
Title: Re: What size bolt to remove Iggy rotor from crank?
Post by: m in sc on September 17, 2019, 03:03:19 PM
M10X1.25
the one from the stock exhaust hanger will work. at least 35mm long total is safe
Post by: Brad-Man on September 17, 2019, 07:25:28 PM
Thanks Mark!
Post by: ~JM~ on September 17, 2019, 08:57:16 PM
Think I used one of the motor mount bolts, some grease & impact gun.
Post by: Jspooner on September 17, 2019, 10:14:51 PM
Quote from: ~JM~ on September 17, 2019, 08:57:16 PM
:clap:
Post by: m in sc on September 18, 2019, 12:00:18 AM
yup, the rear mount top case bigger bolt.  :patriot:
Post by: Dvsrd on September 19, 2019, 03:49:44 PM
Quote from: m in sc on September 18, 2019, 12:00:18 AM
As long as it is M10x1.25.  A previous owner may have replaced it with a more common M10x1.50  (I did once..... ) or worse, a 3/8 bolt (oh, the horror.........)
Post by: pdxjim on September 19, 2019, 11:41:54 PM
Impact is a little brutal ...
Wind the bolt in tight and give it a sharp whack with a hammer, wind it in a bit more and give it another whack and it'll pop loose.
