When installing ring sets in which one ring has a green coating, does the green one go toward the top, or is it the lower one?
:bacon: :bacon: :whistle:
who likes bacon?
Do you put the green ring on top or bottom?
What brand? Never seen a green ring, although all the ones I've had have been OEM
Are you talking about the rings or the expanders (wavy pieces)? Is this for a keystone type OEM piston? If so, there are 2 ring expanders included. The yellow colored one goes under the top ring. HTH
Part number references can be found here in the Tech Library (http://www.2strokeworld.net/forum/index.php?topic=181.msg978#msg978)
I'm asking about stock yamaha brand that come in the green box, flat style for R5. I have two or three sets and they all have the coating on the sealing surface of one piston ring; not the expander (those go on the scrap shelf). There is also a difference in some wiseco nos rings I bought in that one is a dark greyish black and the other is silver. :help: :cheerleader:
Greg, I just went through a few sets of my NOS "green box" R5 & DS7 rings. These were still factory sealed. Most have one green and one plain ring, a few had two green rings. There is a slip of paper in the box that states "Application of the expanders", colored yellow to be coupled with top piston ring, non-colored to be coupled with 2nd piston ring. After careful scrutiny I could see the yellow on one of the expanders. While this isn't definitive, I would think the colored ring is the top one........................................... :twocents: .D
Also, after taking a magnifying glass to the rings, the painted one is stamped "N---50", the unpainted one "2N---50". Don't know if that makes any difference........................D
Thanks guys.
Why didn't they include more info on the expander slip? must be some kind of clue. I think I put the green one on top before so will stick to that method unless someone else chimes in. :metal:
