The 2-Stroke Garage => Haus of Projects => Topic started by: m in sc on November 28, 2020, 07:32:49 PM
Title: 72 R5, round 2.
Post by: m in sc on November 28, 2020, 07:32:49 PM
so, here's the 72 r5 i sold back in 06 to my buddy leo. here's 2 pics from when i owned it before. i wasnt sure what to do with it since i had the 71 i restored and he bugged me to death for it.
It had a 6 speed trans and disc front end when i sold it to him. was a good solid bike.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/100_1957.jpg)
i played around with some j&rs early. they looked awesome, made no power. Chris Locke would up with these pipes eventually.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-r5-chambers-rh.jpg)
about a week and a half ago, my buddy had not run it in about 5 years, wanted to know if i wanted it back. ( i had asked for 1st right of refusal). I paid him what he was asking, which is what he bought it from me for wayyy back. Need carbs unstuck and cleaned, battery,
etc, typical sitting type stuff, but real glad to get it back. Not 100% sure where i'm going to go with it but think i might mod it  a'bit', get seat redone (foam is powder and cover is brittle).
this is the ONLY bike i've ever owned that i've actually bought back.  Im kinda stoked about it.   :cheerleader:
(http://www.2strokeworld.net/wp-content/uploads/72-r5/20201127_150052-scaled.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/20201127_150031-scaled.jpg)
Title: Re: 72 R5, round 2.
Post by: Czakky on November 29, 2020, 09:02:52 AM
She's a beauty!
Post by: suey1958 on November 29, 2020, 09:45:31 AM
Very Nice Mark, Glad you got it back,...We'll be watching to see what you are doing with it.  :clap:
Post by: Kawtriplefreak on November 29, 2020, 09:59:44 AM
Sweet!!
Post by: m in sc on December 03, 2020, 10:53:03 AM
and here we go:
carb cleaning.  the slides were basically glued tot he body, had to soak them pretty good to get them out.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72r5-carbclean_1-rotated-e1607010588115.jpg)
threw an alarm battery in. everything was working, thankfully. going to replace coils as they are OLD, and have a petcock rebuild kit and new throttle cable assembly coming from economy.  :cheerleader:
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72r5-carbclean_2-rotated-e1607010542389.jpg)
still trying to derust tank. slow going in cold weather but its coming. luckily not too bad.
Post by: RDFL on December 03, 2020, 11:28:32 AM
If your using evapo rust or similar, wrap a seed sprouting heating pad over it.
Post by: m in sc on December 03, 2020, 11:51:34 AM
thats not a bad idea. of course, i dont have one of those.  :dawg:
i did however install a heat and ac duct int he garage last night. the tank is sitting right under it.
Post by: Jspooner on December 03, 2020, 01:20:16 PM
Quote from: m in sc on December 03, 2020, 11:51:34 AM
:dawg:
Post by: pidjones on December 03, 2020, 02:12:36 PM
What about a joint pain heating pad?
Post by: m in sc on December 03, 2020, 02:28:56 PM
let me put it this way. no heating blankets or the like are in my house. I have on of those rare women that tend to run warm, not cold.  :bacon: :celebrate:
I'll probably just stick it in the spare room for a few days.  :toot:
Post by: RustyRD on December 03, 2020, 04:26:36 PM
White vinegar will work well in cases where it is surface rust ie not severe. Will not over etch, I have used this many times with great results.
Post by: dgorms on December 03, 2020, 11:50:16 PM
Looks like mine! Let me know if you need any bits or pieces, I have a pretty decent stash of R-5 stuff.........................D
Post by: RustyRD on December 05, 2020, 01:35:03 PM
Quote from: m in sc on December 03, 2020, 10:53:03 AM
and here we go:
The carbs look great, what is your choice for soaking the bodies in?
Post by: SoCal250 on December 05, 2020, 03:05:50 PM
 Looking good so far. :clap: Those carb bodies look nice and clean now.
Post by: pidjones on December 05, 2020, 04:18:47 PM
I've had good luck with either carb cleaner (which is mainly acetone) or just acetone to dissolve varnish build-up in carbs. Just make sure any rubber. plastic, phenolic, etc. is removed first.
Post by: m in sc on December 05, 2020, 05:26:55 PM
thanks! gunk carb (the gallon can) cleaner and 25% wd 40 in the ultrasonic. nothing works better. those carbs sat for over 5 years, they were NASTY.
Post by: RustyRD on December 05, 2020, 07:22:49 PM
Cool, Thanks for the real info. I don't know how many times ya hear about what works well only to find out they have never used it. :umm: What was the soak time ?
Post by: m in sc on December 06, 2020, 08:14:03 AM
in the ultrasonic, 30 minutes. then a spray out with brake clean thru all the passages and jets, then respray with wd. Not quite an hour from on bike to bench, clean.  I did this one morning while having my coffee.  :haw:
Post by: RustyRD on December 06, 2020, 08:23:39 AM
The carbs on my VTR1000 need this attention, and will let my harbor freight ultrasonic stretch its legs.
Post by: m in sc on December 06, 2020, 08:49:20 AM
when i did my concours carbs,  I split the rack and it took a bit longer for obvious reasons.  this was on reassembly. this also sat outside for almost 5 years with the fuel on, then dried out.
(http://www.2strokeworld.net/wp-content/uploads/99-concours/2000concours-proj/c102k-cleanup-run-8-10-20_09.jpg)
this is literally how i bought it. note the tank had sat so long it rusted though. it was disgusting.
(http://www.2strokeworld.net/wp-content/uploads/99-concours/2000concours-proj/200concours-as-bought_-2.jpg)
point being, even on bigger way more complicated 4 stroke carbs.. it works.
just put the solution back in the can when done to avoid smell. take out any diaphrams and hand clean those.
:twocents:
Post by: RustyRD on December 06, 2020, 10:31:02 AM
Thanks for the additional info, I have used gunk in the past for carbs in automotive application, however without the wd40. I will try this brew out for the VTR carbs. :clap:
Post by: m in sc on December 08, 2020, 02:25:46 PM
nothing too exciting, but did a bit of cleanup. the seat foam had turned to dust, so had to get that cleaned out.  also the tank was pretty rusty inside,/ have a petcock rebuild kit coming from john at economy, and a complete throttle cable assembly.  In the meantime, soaked the inside of the tank with some 'metal rescue' and water for about 4 days. came out really well, especially considering what it looked like.  I'll probably hit it again to get the stuff off the spine. But for now, its pretty good.
this has mineral spirits in it now neutralizing.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/tank-cleanup-72r5_3-1.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/tank-cleanup-72r5_1.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/tank-cleanup-72r5_2.jpg)
now starts 2nd kick cold.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/tank-cleanup-72r5_4.jpg)
Post by: RustyRD on December 08, 2020, 04:28:49 PM
I like the auxiliary fuel setup, carbs look great in place. Fuel tank is making a nice recovery.
Post by: Djg8493 on December 09, 2020, 10:18:49 AM
Quote from: m in sc on December 08, 2020, 02:25:46 PM
Does the mineral spirits stop it from flash rusting again?  If so will that hold for a while if you are not ready to fill it back with gas?
Post by: SoCal250 on December 09, 2020, 12:28:24 PM
Is Metal Rescue a better option than Evapo-Rust in this situation? Not really up on all the rust treatment solutions and preferences.
Post by: Djg8493 on December 09, 2020, 12:33:00 PM
I'll give a comparison in a few days, I am doing a similar condition tank with Evaporust now.
Post by: m in sc on December 09, 2020, 12:59:26 PM
ive used both. about the same, i think evaporust is a -tad- stronger but i could be wrong. end result is the same .   :twocents:
Post by: Djg8493 on December 10, 2020, 02:47:45 PM
About 8 hours in and so far the Evaporust looks to be working well.  you can see the line in the gas cap where I had it laying on.  I have also heard that it can be damaging to Aluminum if left on too long.
Post by: m in sc on December 12, 2020, 10:33:59 PM
so small update. tanks clean, got rebuild kit from john at economy and good to go.
also, swapped out coils. for moment, relatively stock, ie, points. so, until i change to something else, i figured id try a trick i learned at the gap this year. SV650 replacement coils are 3 ohm and DIRT cheap on ebay.  so, figured id try a set on here.
had to make sub harness for spade to bullet, but did that and good to go.  bolted in to back spot, used spacer and works perfect.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-coils-shocks_1.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-coils-shocks_2.jpg)
also, had the typical progressive style shocks. But i always hated the stupid halc shrouds on them, so took them off.  much better i think
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-coils-shocks_9.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-coils-shocks_8.jpg)
waiting on clutch and gaskets, will swap out rd cover for proper r5 one on clutch side.  soon. also have some new cables from economy coming soon.
Need to get the gauge mounting situation sorted out as well. just don't like it. got the beverly shear and some aluminum, going to fab up a new mount rd trees/r5 gauges.
did get a new 13mm master on it i had laying around much better feel.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/72-coils-shocks_6.jpg)
not the most exciting project but getting the baseline sorted.
Post by: m in sc on December 21, 2020, 02:23:56 PM
chambers on, gauges remounted (no pics yet) and 1st testride done. first time its moved under its own power in 6 yrs, min.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/testride-1-72.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/chambers-fitment-left-72.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/chambers-fitment-back-72.jpg)
Post by: RustyRD on December 21, 2020, 02:53:24 PM
Thats cool, sunny and 61 here in south GA. I found one of my old RDs on facebook but just cannot link up with the individual. Your bike looks good those engine covers look like they have been well taken care of. I am sure it will bring many hours of enjoyment.
Post by: m in sc on December 21, 2020, 03:27:59 PM
thanks. should be good.
I repainted both of them actually. just missing the decal on the oil pump side. that DID have an rd clutch cover on it.
a bit of history, back in around 03 or so i was going to use this as a track bike. had it set up as such, never did, put it back to relatively stock and sold it to Leo, added the disc for him later. Im glad i never got the track bug, especially on this one.
Post by: RustyRD on December 21, 2020, 06:11:17 PM
I have a line on a R5 with a 250 reed valve top end, you seem to be fond of the R5. What is your input on the R5.
Post by: Kawtriplefreak on December 22, 2020, 12:55:08 AM
Looking good  :clap:  :clap:
Post by: 85RZwade on December 22, 2020, 09:07:05 AM
How do those chambers sound? They look just right on there!
Post by: m in sc on December 22, 2020, 11:01:18 AM
Quote from: RustyRD on December 21, 2020, 06:11:17 PM
I like all yamaha twins. I always felt R5's looked better, hands down. Ive owned 4 total, 2 of which i currently now own, ive owned many more rds.
I mean, its essentially the same bike as an rd aside from obvious differences. smaler ones are the lack of a lower frame rail mount for the muffler, battery  box mounting and air box differences, and the motor and trans stuff. also the friction dampener, drum brake, etc.  however, an r5 can be turned into an rd pretty easily.
I liek the midrange pull of a piston port. easier to ride IMHO .  (stock to stock). an rd250 or 350 power is much more abrupt at 5500, as we all know, due to a slight dip before the harmonics get right , and most useful tuning,t o me, gets that smoothed out on a reeded motor. they got some of this sorted with the 400
but back to the R5.
My 70 is just a neat survivor, always runs well, I have -no- idea whats going on in the motor as ive never even pulled a head off.  its just a nice stock example of one thats a rider.
The 72 is going to obviously be more of a 'bridge', to me, between that and my 2 hot rodded rds, which are both a bit over the top. They both ride and run really well and can be used all day long believe it or not. I even took the lightweight out on a 4 hour group ride a few weeks ago. reliable as the day is long.
The 72 has the basic upgrades the rds had, 6 speed transmission, disc brake, will get electronic ign (still on points now) and now, chambers.
I just like them like i would an RD. they tend to be thrashed less. Im quite fond of the RD250 top end, they make a really good amount of power and are often overlooked, but they have much more transfer area in the ducts than the 350s do due to the bore decrease.  That sounds like a cool project for sure.
IF the r5 were my ONLY yamaha twin, id be tempted to fit reeded 350 cyls, for sure. But id def consider the one you are looking at with the 250 topend.
the beauty of an r5 is all the machanical shit for th emost part swaps, and rd support is strong.
Post by: RustyRD on December 22, 2020, 04:05:26 PM
your right as far as converting to rd, I Thank you for the input. The R5 is basically complete minus correct seat and side panel. engine is not seized however it has a RD 250 reed valve top end. Fellow is asking 550 for the bike.
Post by: m in sc on December 22, 2020, 04:10:52 PM
dude. buy it.
:toot:
Post by: RDFL on December 22, 2020, 04:24:21 PM
If you don't let me know, not far from me.
Post by: RustyRD on December 22, 2020, 04:36:27 PM
OK I think you convinced me, It needs a lot but it is not a basket case. Now when I post pics of it no laughing....alright :whistle:
Post by: m in sc on December 24, 2020, 08:22:19 PM
Video of chambers with sound. Not dialed in , raining out right now.
Post by: dgorms on December 24, 2020, 09:37:15 PM
Rusty, buy it! I got side panels I'll give you..............................................................D
Post by: 85RZwade on December 25, 2020, 08:48:46 AM
 :clap: thanks for the music  :thumbs:
Post by: RustyRD on December 25, 2020, 08:55:21 PM
Soon as I can catch him I will do it.  The R5 sounds great pipes have a deeper tone.   :celebrate:
Post by: Evans Ward on December 26, 2020, 09:36:55 AM
Sounds very good Mark!  :metal:
Post by: Greaser Greg on December 27, 2020, 11:12:49 PM
 :cheerleader: Great thread, everyone!   :bacon:
Post by: m in sc on December 28, 2020, 02:43:17 PM
bit of an update.
got tuning dialed in a bit. now need to swap to 7 disc clutch, won't hold even with new plates with eh stock 6 plate.
stock r5 carbs, 169p-0 emulsion tube vs the 169o-0, 140 main, 5dp7 needle, 2nd clip, 35 pilot (needs a 37.5 or a 40), airscrews at a hair under 3/4.  k&n in y boot.
not a 'legit' plug chop but feels good, pulls really strong over 5k.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/rhplug.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/r5sunset-tune-2.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/chambers/r5sunset-tune-1.jpg)
Post by: soonerbillz on March 08, 2021, 02:04:13 PM
Is that the correct Headlight shell? Or from something else?
Bike looks great.. can't wait to start actually building mine.. Buying parts is fun.. but man ... The waiting is killing me!
Post by: m in sc on March 08, 2021, 02:06:51 PM
headlight is the chrome one from economy cycle from yrs ago with an led bulb H4 and i put the high beam indicator in from the stock headlight. thanks, its fun. :D
Might actually bring this one to the gap this year.
Post by: m in sc on March 22, 2021, 11:54:02 AM
received my vape CDI from john at economy last week, and also installing a zeeltronic (spare i had) on this to give it better charging, much better spark and a rev limiter.
keep in mind, its an rd bottom end but same as an r5 for the most part. had to notch the LH cover to clear the pickup.
Also, used a long thin piece of welding wire to snake up a neutral wire through the vape harness.
Not a show bike by any stretch.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_01.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_02.jpg)
notched to clear pickup.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_07.jpg)
green wire = n
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_05.jpg)
loctite all the screws. double check the pickup mounts as well, they aren't usually 100% tight.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_06.jpg)
timing pointer i made out of aluminum for my cdi  yamahas.  timed at leading edge of sharpie.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_11.jpg)
the zeel lets you set the initial timing static angle, this wound up being 37.2. what you do is set it up advanced, somewhere under 50 degrees, and then adjust it digitally under setup.  max advance im using is 22 on this motor so far. retard goes to 17 degrees at 9k.  I just write the static on the rotor
for later ref
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_10.jpg)
zeel box mounted on front of battery box. the nice thing about usiung a zeel is it requires power to run, so you power this off the old coil lead and your ign works as stock with the key and kill.   no relay needed.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_12.jpg)
coil mounted. i drilled 2 holes on lower LH brace, used spacers and 35mm stainless m5 allens to mount up.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_09.jpg)
ALL stock wiring intact, (battery harness is saved as well ) i didn't cut a single wire. can be reversed.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cdi/72r5-cdi_08.jpg)
side note, you HAVE to used resistor plugs OR caps to run the zeel. no way around it.  I forgot, wouldn't fire off without em, so i put on 5 ohm resistor caps.. otherwise, it scrambled the zeel.   :eek:
did a quick testride last night, def better.
Post by: soonerbillz on March 22, 2021, 12:04:39 PM
Nice!
Thank you so much for posting this. I'll be doing this at some point. Nice to have a visual.
Where did you wire the caps into?
Post by: m in sc on March 22, 2021, 12:10:05 PM
the plug wire ends.
Post by: soonerbillz on March 22, 2021, 12:35:58 PM
Quote from: m in sc on March 22, 2021, 12:10:05 PM
the plug wire ends.
You mean like these?
https://www.amazon.com/NGK-LB05EP-Resistor-Spark-Plug/dp/B001KOL5SG/ref=sr_1_3?dchild=1&keywords=resistor+plug+caps&qid=1616430872&sr=8-3
Post by: m in sc on March 22, 2021, 12:57:48 PM
yup. pretty common.
IF you dont run the zeel its not needed. just fyi.
Title: Tool tray
Post by: m in sc on July 22, 2021, 11:43:54 AM
Havent updated much, but the 72 just seems to be running really well all year. But, I did a bit of cleanup on it and added a tool tray under the seat.
What i did was bend up some aluminum, and used speed nuts to mount the upright tot he stock battery box (no cutting nec to stock stuff). then bent up the top part and used an m5 bolt with some heatshrink on it to sit in the stock 'pin' location of the airbox.
this would work on an rd as well.  (k&N y boot solution). I use one of the alarm batteries as well hence the extra room in there.
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-tooltray_2.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-tooltray_3.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-tooltray_5.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-tooltray_4.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-tooltray_1.jpg)
(http://www.2strokeworld.net/wp-content/uploads/72-r5/cleanup-tooltray-july21/72r5-cleanup02.jpg)
Post by: Kawtriplefreak on July 22, 2021, 05:47:45 PM
Nice!!!
Post by: m in sc on April 09, 2024, 01:03:45 PM
so, a sa LONG overdue follow up, this is the biek i put the ebay RD cyls on. 6 mos ago i swapped them out and its been really good. I wanted to put in some v force reeds vs the stockers,  remove the reed spacer and just get a look at the face of the piston. this motor sees 10 pretty regular, and gets ridden fairly frequently.
Reeds are for rm100/kx85. drill holes out to 9.5 mm and they bolt right in.. NO cyl cutting. they are also 4mm shorter than a stock rd reed cage so the boost port gets unshrouded a bit.
Cyls and pistons are ebay specials, $194 set that come sup. JUst had to chamfer the ports & remove the intake tab on the piston like a banshee piston.
carbs are stock rd350 carbs , no dave f mod.
the v-force reeds alone, no other changes, def smoothed out the transition intot he powerband. zero jetting changes needed.
also did a compression check after 6 mos. about where it was from 'new'. heads are unmodified r5 units, so not super awesome.
(https://2strokeworld.net/wp-content/uploads/72-r5/vforce-and-compression_72R5_1-rotated-e1712677582366.jpg)
(https://2strokeworld.net/wp-content/uploads/72-r5/vforce-and-compression_72R5_6-rotated-e1712677550560.jpg)
(https://2strokeworld.net/wp-content/uploads/72-r5/vforce-and-compression_72R5_5-rotated-e1712677518142.jpg)
(https://2strokeworld.net/wp-content/uploads/72-r5/vforce-and-compression_72R5_3-rotated-e1712677404817.jpg)
(https://2strokeworld.net/wp-content/uploads/72-r5/vforce-and-compression_72R5_4-rotated-e1712677464881.jpg)
as the bike currently sits:
(https://2strokeworld.net/wp-content/uploads/72-r5/20240312_094014-scaled-e1710259032149.jpg)
Post by: Kawtriplefreak on April 09, 2024, 06:11:10 PM
 :celebrate:  :celebrate:
Post by: RustyRD on April 13, 2024, 10:13:22 PM
The seat look great, the whole bike looks great, is that the Texavina seat? How long did it take to arrive from Vietnam ? I think that's where they ship from.
Post by: m in sc on April 14, 2024, 12:26:39 AM
thanks. yes, it was just under 4 weeks.
Post by: soonerbillz on April 15, 2024, 10:04:33 AM
That's awesome 👌
