The 2-Stroke Garage => Turning Wrenches => Topic started by: Still biking on December 20, 2020, 04:57:48 PM
Title: alteration of intake port on RD350 cylinder
Post by: Still biking on December 20, 2020, 04:57:48 PM
Check the alterations on the intake port on these cylinders on Ebay.  Also, cut out above intake of cooling fins.  Any Ideas why this was done and if it improves performance?  see https://www.ebay.com/itm/333830105894?ViewItem=&item=333830105894
Title: Re: alteration of intake port on RD350 cylinder
Post by: Seizer on December 20, 2020, 08:14:33 PM
Maybe they relief cut the fins to fit in a different frame?
Post by: bitzz on December 20, 2020, 08:38:27 PM
My guess would be it was modified to accept a balance tube intake like a RD400 or RZ.
The way the port is hogged out probably a RZ or Banshee intake.
Post by: SoCal250 on December 21, 2020, 11:45:24 AM
Looks like he was running them with the tabs still on the piston skirts.
Post by: m in sc on December 21, 2020, 12:21:31 PM
Quote from: bitzz on December 20, 2020, 08:38:27 PM
^ this.
ive seen them angled towards the cyl as well using straight intakes.
Post by: RdsOnly on December 22, 2020, 01:22:00 AM
nPERIOD CORRECT- POWER MODS
jtOT WORTH COMMENTING ON- SO WRONG FOR
Post by: racerclam on January 01, 2021, 02:16:59 PM
Just stupid grinding the reeds cover those trenches , all it did was increace crankcase volume
Rich
Post by: teazer on January 01, 2021, 08:52:49 PM
And that would generally be a good thing as long as the pipe can use the extra volume. Let the waves do the work...
