Loctite For Injection Nozzles
Started by IICYCLE, April 11, 2020, 06:45:14 AM
IICYCLE
 Looking for type of locktite to seal injection nozzles. I've done a search but could not find it.
Thanks
thatguy
I used Loctite 609 with 7471 primer. Clean well and be quick though.
Safety wire them in. You dont need to glue them.  Once glued, twice screwed.
For the injection nozzles going into the carb, I remember reading online to use a small amount of rubber contact cement.
I used Yamabond on one of mine that was loose.
IICYCLE
Thanks for all the suggestions. Im going with the the #640,it looks like the right application.
Thanks
I've been doing that for 25 years that way...never had one fall out afterwards.  And still on my huge 50ml bottle.
Here's the spec sheet and the reason so expensive, $55 a big bottle.
http://media.hiscoinc.com/Volume2/d110001/medias/docus/205/Loctite%20Corporation-30769_135520-TDS_VD.pdf
IICYCLE
Quote from: SUPERTUNE on April 14, 2020, 10:38:33 AM
Thanks for your help
2steve
Since carb tuning is still going on after the update porting by Chuck, I'm just doing the zip ties.  So far, so good:
