135-140 HP CASE REED H2
Built by Henry Wedge. 1st hand experience, it is indeed insane to ride.  :devil:
TZ750 Manifolds
Started by mavguy, May 22, 2020, 07:36:53 PM
EE
One of the people i reached out to was Chariot Racing because i've been using their billet banshee manifolds more and more and i just got a reply back: "Yes they are that bolt pattern. They fit perfectly. Boots for 35 to 41 mm carbs and up to 49 mm with modification to the intake. Just a little grinding." So here ya go:
https://www.ebay.com/itm/230497012936?ul_noapp=true
DesmoDrew
#16
Two things to consider:
   1- If you are using OEM Yamaha TZ750 or Blaster reed cage assemblies, the OEM (or TZ-Mike) manifolds will have the 'ears' which protrude into the cage to smooth the flow (just like stock RD manifolds) and fit into the reed cages.
    2- If you plan on using V-Force reed assemblies, the 'ears' are irrelevant and will need to be trimmed off the OEM Yamaha (or TZ Mike) manifolds, so an aftermarket billet manifold, with a smooth face, will work just as well.
:twocents:
GRA2STROKES
Sorry I forgot about this I'll look this weekend.
Garrett
mavguy
Folks my project is nearing the end.would appreciate any help procuring TZ manifolds.
have you reached out to jim hinshaw @ fast from the past? he doesn't sell them but probably knows who does.  or contact fondseca.  One of them knows.
and what happened to mfactory west and tz mike? I know he used to carry them.  :twocents:
Do you need 4? I think I have 2.
Quote from: 1976RD400C on October 09, 2020, 11:52:51 AM
20201009-112915" border="0
Unless these ^^^^^ will work for you there aren't a lot of options. TZ Mike is your best option. No, they are not cheap. Looks like you missed out on the set I mentioned were on EBay awhile back.
