May 17-23
Finally getting close to having a ridable motorcycle
Started by ElFuegoBlanco, August 27, 2022, 12:07:32 PM
Won't rev out? That's not normal. Even on a rich bike, it should rev out, only in the high top end at speed will you get garbled running (when rich).
Too lean, well the bike just won't like revving. OR, consequently it will like revving so much it goes pop. Lean is mean... they say.
ElFuegoBlanco
Quote from: Striker1423 on August 29, 2022, 02:35:17 PM
I'm looking at the carb sync section in the Haynes manual. The picture doesn't match up with what I'm seeing. The dimple on the slides is offset from the portal, so I can't tell where it should be on wot. In the picture, it's centered with the bottom of the dimple aligning with the bottom of the portal.
So maybe it's a cable adjustment issue? I can also go back up on the main to enrich it a bit.
Clem710
I dont think mine is even interesting until above 5k and you can pretty much ham fist it from idle and only winds up a bit, Dave F, 160main iirc, stock pipes/cylinder, crossover.
I'm thinkin u got something else goin on there. Certain you are getting fuel?  Fresh, clean fuel? Certain the carb pieces are correct? Center tube things cleaned and installed all the way in for sure?  Needle mounted correctly? No monsterous air leaks?  Exhaust and air filter clear for sure? Pistons not backwards?(I forget what this does)
Just some suggestions down some other paths, GL
ElFuegoBlanco
Quote from: Clem710 on August 29, 2022, 05:03:28 PM
Yep. Tubes are new and installed correctly. Needles are, too. I just cleaned the petcock and replaced the needle valves. Air filter is brand new (30 miles on the bike since I renewed it). I just did the Dave F mod over the weekend, so it's definitely clear there, too.
The fuel is fresh, but could be fresher. I might throw it in my pickup and swap it with some ethanol free from across town.
Next time I take it out (cutting grass aka drinking beer tonight), I'll try going ricer on the needle and main. 250 was toooo rich and fouled the plugs. I'll try 220 again. Oh, and I'll go ahead and pull and clean the air filter because you never know.
Thanks for the insight.
Rob
Quote from: ElFuegoBlanco on August 29, 2022, 03:48:06 PM
Are you saying that you can not see the dimple in the sight glass on your carbs? Are your slides in the correct way around?
Clem710
Semi old gas shouldnt matter much if everything is right, I was thinkin float height or actual delivery to the carb.  Make sure the pipes are clear, the popcorn machine is usually pretty obvious if one isnt firing or flowing and they are pretty slow on 1 cylinder.
Only a couple screws to check timing too if just to see if it looks about right.
Slides reversed? I forget how that acts. They do run okish with the crossover tube off.
ElFuegoBlanco
Quote from: rodneya on August 29, 2022, 05:42:41 PM
The slides are 100% definitely in the correct way (I made that mistake already a few months ago)
What I'm saying is the dimple isn't aligned with the center of the sight glass. It's off the the left, so at wot, the 7 o'clock position of the dimple meets the 7 o'clock position of the sight glass. I posted a pic a little earlier with the dimple raised up a bit to make it easier to see.
In the pic in the manual, the 6 o'clock position mates up with the 6 o'clock position of the sight glass. I hope that makes sense.
But the slides are right way round. And they slide in along the guide on the carb just fine. It's just the dimple is off to the left on both carbs. Oh. It's possible they're not the stock slides. I'd have to look at past posts to find the part number.
Quote from: Clem710 on August 29, 2022, 05:51:38 PM
Lol I screwed up and reversed the slides during the rebuild. I double check every time now. I can check the timing again now that the coils are fresh. I believe I have it set at 2.1mm btdc.
Clem710
Just have to check it to be sure the correct one is firing and theyre semi close to where they should be gap and timing.
Again, dont know what happens with plug wires/points reversed, I'd bet nothing good and its also easy to check, GL
just a thought. make sure the slide aligning pin isnt pushed out some on the other side of the carb. if it is.. this will allow the slide to rotate in the bore. Not nec saying thats the issue but worth looking at.  :twocents:
ElFuegoBlanco
Quote from: m in sc on August 30, 2022, 10:08:52 AM
All good there, though I just found out how easily the locating pin can be moved.  :whistle:
I think I'm just crazy and looking at it from an angle. I'm just not sure what else would limit the revs as long as it's not the throttle limiting the pull.
These bikes really only breath and move past 4500rpm or so. If it won't go past 5k, you aren't anywhere near the power band yet.
As far as the aligning notch versus sight glass, once you align the notch to the 7 oclock position, stick your finger in the bell housing and feel how much the slide protrudes down past the top of the carb body cutout. It should be flush, or just proud of the carb body at WOT. You should also be able to push up on the slide and get another 2mm or so of upward movement. That ensures you aren't binding up at the top of the carb.
