75' RD350 chain swap to 520..
Started by grcamna3, April 25, 2025, 07:48:47 PM
RDnuTZ
If it was me, I'd get the exhaust + intake sorted and a basic state of tuning to use as baseline before messing with anything else. Always solve for 1 variable at a time and build off that. On the clutch grabby thing, an old dirt bike trick we use on bikes sitting for years is oil change using detergent ATF to break loose clutches. Fill, fire it up and just sit there in neutral exercising clutch in and out until you feel clutch effort change. Then ride it around a bit still exercising the clutch. Get it good and hot, then drain ATF and see what it looks like. If dirty, repeat process. If relatively clean fill back up with your regular oil and try it out. About 50% of the time the clutch works normal with no slipping or grabbing. YMMV  :burnout:
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
grcamna3
I see mentioned here about other things to go from 250-350 top-end swap,which leads me to two questions: will the original RD250B 'tall slide' carbs(one guy local to me said 250 carbs are 26mm,but the RD350 carbs are larger at 28mm)work ok with the RD350 top-end, & are changing all the cylinder studs out from the 250 up to the OEM 350 studs a good upgrade ?
rd250 carbs are 28mm. ds7 carbs are 26mm. (wrong 250). the jetting is obviously different but the carbs themselves will work just fine.
Quote from: grcamna3 on April 26, 2025, 03:20:35 PMI see mentioned here about other things to go from 250-350 top-end swap,which leads me to two questions: will the original RD250B 'tall slide' carbs(one guy local to me said 250 carbs are 26mm,but the RD350 carbs are larger at 28mm)work ok with the RD350 top-end, & are changing all the cylinder studs out from the 250 up to the OEM 350 studs a good upgrade ?
The 73-75 RD250 and RD350 carbs are the same, both are Mikuni VM28. Yamaha changed the design in the middle of the 1974 model year, going from a low-top design to the high-top design. This was done "to improve the waterproof design of the carbs and to prevent slide sticking". (See Yamaha Tech Bulletin M4-061)
The switch to the high-top version affected all bikes built from the following engine numbers
RD250A 352-206520 and RD350A 351-213364.
No reason to change out your carbs.
Cylinder studs have been discussed on here recently. You can swap out the shorter 250 studs for the longer 350 version 90116-08064-00. Technically it's the proper thing to do but it's not required.
RDryan
Quote from: RDnuTZ on April 26, 2025, 01:11:00 PMIf it was me, I'd get the exhaust + intake sorted and a basic state of tuning to use as baseline before messing with anything else. Always solve for 1 variable at a time and build off that. On the clutch grabby thing, an old dirt bike trick we use on bikes sitting for years is oil change using detergent ATF to break loose clutches. Fill, fire it up and just sit there in neutral exercising clutch in and out until you feel clutch effort change. Then ride it around a bit still exercising the clutch. Get it good and hot, then drain ATF and see what it looks like. If dirty, repeat process. If relatively clean fill back up with your regular oil and try it out. About 50% of the time the clutch works normal with no slipping or grabbing. YMMV  :burnout:
Wow,that is very interesting. I actually have almost a gallon of ATF on a shelf,tempted to do this :whistle:
grcamna3
Quote from: SoCal250 on April 26, 2025, 03:36:13 PM
I prefer to change the cylinder studs to the longer 350 part# you posted.
Will all 8) be the same part # ?
Quote from: grcamna3 on April 26, 2025, 06:28:35 PMI prefer to change the cylinder studs to the longer 350 part# you posted.
Yes, 8 pcs. A stud extractor tool will make removal easier. There are some discussions on here about it.
Some examples:
https://www.summitracing.com/parts/wmr-w83203
https://www.summitracing.com/parts/lil-71200
grcamna3
Quote from: SoCal250 on April 26, 2025, 07:27:44 PM
Some examples:
Thank you very much for this information.
I'm going to start collecting parts(as I locate them)to do the swap,and then go for it.
I'll run it as a stock 250(including stock gearing and chain,for now)after I go all through the list of things I would normally do(including the full 50 yr. old electrics cleaning and servicing)when buying a new-to-me bike:by the book.
I plan to completely do the front-end next,including tapered steering bearings and .60Kg Race-Tech straight rate springs.
grcamna3
Quote from: m in sc on April 25, 2025, 07:54:20 PMyou can run like 100 hp thru a 520, rd isn't going to do anything to it. fwiw john at economy cycle sells the whole kit specifically for an rd
Ok Mark.  :cool:
Yamanatic
Just an aside, 1970's TZ250/TZ350 sprockets are 520 and some TZ rears are drilled for 4 or 5 stud mounting - TZ countershafts use the same spline as RDs. The alloy rears are very pretty!
WW
grcamna3
Quote from: Yamanatic on April 28, 2025, 03:11:47 PMJust an aside, 1970's TZ250/TZ350 sprockets are 520 and some TZ rears are drilled for 4 or 5 stud mounting - TZ countershafts use the same spline as RDs. The alloy rears are very pretty!
WW
70's TZ sprockets compatible? Ok  :burnout:
Vincenthdfan
Does anyone make steel rear sprockets for 520 chains on the RD's?  All I could find when researching this was aluminum, which I dont care to run based on past experience.
grcamna3
Quote from: Vincenthdfan on April 29, 2025, 07:44:13 PMDoes anyone make steel rear sprockets for 520 chains on the RD's?  All I could find when researching this was aluminum, which I dont care to run based on past experience.
I prefer steel on my RD road bike also.
Vincenthdfan
Quote from: grcamna3 on April 29, 2025, 11:10:43 PM
Ever found any for RD's?
grcamna3
Quote from: Vincenthdfan on May 01, 2025, 03:52:40 PM
I haven't found any yet.
