Maintenance free battery for 73 RD 350
Started by MRDRcycle, December 06, 2019, 08:32:09 PM
Motobatt makes great batteries.  I have on in my KH400, about 5 years old and running strong.  A little more expensive than Bikemaster, maybe worth the extra bucks.
MRDRcycle
ugh. I think I was mistaken about the direct fit for that motobatt. It looks like it might be too big.
zedixe13
MRDRcycle
#18
arrg. I typed in the wrong battery part number (12n5.5-3b vs. 12n5.5A-3b) and I'm thinking the motobatt will be too large to fit in my battery box.
Does anyone have part numbers for a powersport battery that will fit? I looked at the sigma tek, but its seems like most are 12v 4ah. I haven't looked at the alarm batteries yet. They look like they are an easy fit, but I really don't know where to start looking on those.
Does anyone see anything wrong with either of these batteries? Is it bad to go a little over on amperage? My conventional battery is 12v 5.5ah.
Moto Classic YTX4L 12V 4.5Ah Maintenance Free Sealed AGM 90CCA Battery w/ 30 Mo. Warranty Coverage  4.5 x 2.7 x 3.5 inches
Moto Classic YTX5L 12V 6.5Ah Sealed Maintenance Free AGM 125CCA Battery   4.5 x 2.8 x 4.3 inches
https://www.amazon.com/Moto-Classic-PowerSport-Batteries-YTX5L/dp/B07NBJ42RG/ref=sr_1_9_sspa?keywords=yuasa%2Bagm%2B5ah&qid=1575786072&s=automotive&sr=1-9-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyS0ZWTVBVMEpBWEtYJmVuY3J5cHRlZElkPUEwOTc5MjkyM0pVUk9QWlFPNFpWVyZlbmNyeXB0ZWRBZElkPUEwNjA1Nzc5M0I5RzNBTFQwMTdDOSZ3aWRnZXROYW1lPXNwX2J0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU&th=1
MRDRcycle
ah.... I see its 4.5 not 4.0 for the sigma you sent over. Does the 4.5 inch width fit into the battery box well?
The stock yuasa dimensions are:
Length: 4 1/16 in.
Width: 3 9/16 in.
Height: 4 1/2 in.
I cut up a inner tube to wrap some around it, it's slightly smaller than stock one same height.
Old Brit
Quote from: MRDRcycle on December 08, 2019, 03:40:50 AM
http://www.motobattbatteries.com/motobatt-mb5-5u.html
I also found this one. Although it is 7ah, it says it's a direct replacement for my yuasa battery and that it will fit the RD350.
I've got a Motobatt MBTZ7S from a bike I bought for spares in my '74 RD350, small bit of foam used to secure it, jobs a good'un 👍
http://www.motobatt.com/MBTZ7S
MRDRcycle
#24
Long story short, the yamaha dealer gave me an AGM battery for free since my old conventional battery was under warranty. The one I got is the same (or very close) height and width as the old battery. The height and width fit perfect in the battery "mount/holder." I couldn't find the right foam, so I  added some bike inner-tubes like one of the guys suggested to make up for the shorter depth.
The battery part number is CTZ7S Fire Power (replaces YTZ7S). 12V 6ah.  If you are interested, I've attached a picture. Thanks again for all the great info!
I finally had time to install it. Hopefully I'll be shredding the streets soon  :metal:
Problem solved and back on the road! Bundle up...
Wade
