RD400 shift shaft modification
Started by msr, April 22, 2024, 02:45:49 PM
msr
The left side cover of my RD400 where the shift shaft comes through had worn into an oval allowing far too much play in the shifter. Yesterday, m in sc and I (okay mostly him) used his mill at work to open that hole up and sleeve it. A tack weld to keep it in place and some paint and it looks like it was manufactured this way.
Good, simple design to solve a frustrating problem. Thanks Mark!
fwiw, thats a 12mm id shock bushing that came with some shocks.
you get the cover bushed you dont need that. that's a bandaid for the problem we solved on matts bike.
RDnuTZ
is the zirk/grease fitting still functional with bush in place there?
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
YES, after the bushing was pressed in it was drilled and deburred.  :toot:
