Left exhaust excessive smoke RD350
Started by RD350NL, April 04, 2025, 05:14:15 PM
RD350NL
Hi all
Just have my rd350 running and I encounter the following issue:
Left exhaust is smoking much more than the right one, also when hot
Left spark plug is very dark also. Right spark plug has a nice brown colour.
Looks like the oil pump is distributing oil unevenly. Does anyone has experience or tips with this issue?
Its the left exhaust when you sit on the bike so I dont expect an oil seal,gearbox oil is also not dropping, plus the amount of smoke is not extreme, just a lot more than right.
Bone stock 73 rd350.
140 main
Clip 4
Pilot 25
Air screw 1.75
Runs like a dream!
Thanks for your help already
no. fairly impossible to do that since they feed from the same chamber. you can swap the lines at the pump to verify. my guess is carb related
RD350NL
Thanks for that insight. What could cause it from the carb?
RD350NL
RD350NL
Synched the carbs and replaced the oil lines as they were hardened.
