Right cylinder running lean
Started by Rhino363, August 26, 2020, 08:01:41 PM
Quote from: Rhino363 on September 01, 2020, 08:15:09 PM
Everything has been cleaned and wire thru passages I can get to.all new mikuni jets. I didnt set fuel height just the float height but I have swapped floats between the carbs with no difference. Is it ever common to run larger jets in one carb? I didnt replace the main nozzle that the main jet threads into but they look to be ok.
Thanks
Yes but never more than one size different side to side.
Rhino363
I think I may have found my issue i swapped the main nozzle jet over from carb to carb and it followed to the other side. I just ordered 2 new ones and am having them overnighted.
I had that once on an r5, good catch. thats a hard one to diagnose.  :clap:
Awesome. It takes time to diagnose, but you'll figure things out.
