brake rotors
Started by ace787, April 13, 2020, 05:59:50 AM
bitzz
I have run a 297mm XS650 disc with an adapter for a RD caliper on a RD400 racer for years. Never ran out of brakes.
A TZ has the same disc, just thinner, 5mm thick
It is easy to adapt a 297mm disk off an early CB750
If you can find a slider off an early TZ you don't need the adapter.
I am under the impression that a disc off a '89 FZR400/600, or an early FJ is the same dimensions, so a direct bolt on and is a floater. (There is no REAL performance gain with a floater, but they don't warp like a solid mounted disc).
I bought a TZ350 with a dual disc setup off a TZ 750. I rode it ONCE, then swapped in a single disc setup. It slowed the steering noticeably with no real gain in brakes.
Quote from: bitzz on April 25, 2020, 07:00:25 PM
I
Would probably need a spacer too.
