general babbling about master cyl and the single blue or gold dot caliper
Started by m in sc, July 22, 2020, 05:27:10 PM
What's the difference between a silver FZR caliper and a blue dot? I'm running a 13mm master from a quad or something, I got it for like $15 used. Asides from needing pads, the setup with the stock fzr (silver) caliper it works very well. I'm also running an off brand aluminum center wave style disc that I bought used on eBay. It looks great and works fine for the street. Loads of stopping power and very light.
i had good luck the silver fzr caliper and 13mm master a swell, id imagine piston area. ?
well the total piston area is right at 2558.84 for the gold or blue dot calipers. (each caliper) they are 27mm and 30mm, 2 of each in each single caliper.
  actual ratio is 26.926 which 27, I believe, is considered ideal. (2558.84/95.03 )
bitzz
Quote from: m in sc on July 27, 2020, 01:15:03 PM
27 may theoretically ideal, but there is some preference in there too.
If the "ideal" on the chart is 27, I have found I prefer a little less, maybe 25.
My rider prefers MORE, so he may get 28.
Radial masters are where it's at.
of course. they don't take into account lever geometry either, that makes a huge difference. But, generally speaking as a rule of thumb, thats the target then adjust for feel.
Quote from: m in sc on July 26, 2020, 12:07:55 PM
actually a lot of people prefer a 13 on a stock rd caliper. I tried it didn't like it, prefer a 14. have a 12 on the rear on on the lc, gives really good feel with a much shorter brake lever.
:twocents:
I agree, 13mm would feel too light and squishy for me. I like a little more feedback with the controls.
I noticed the rear brake on my 400 isn't as positive feeling with the rear sets. It feels mushy. Not bad enough to change anything, but I thought it odd as my assumption was that it would feel stiffer with the shorter lever.
