Started the Hybrid build
Started by dusty350, July 27, 2020, 02:51:11 PM
dusty350
The head bolts were on my other 400 when I got her back. So I didn't buy them, but I did swap them over for this engine. I've looked for another set but never found anywhere that does them, yet. You can get them easily for Lc's and Pv's, just not aircooleds :umm:
Dusty
bostontrackrat
dusty350
The new Allspeed pipes turned up, so I fitted those with new brackets so they could bolt to the redesigned rear set back plates. Also made a bracket from 3mm ali for the rear master cylinder, plus fitted the rearset pegs and controls;
20201209_125401 by dusty miller, on Flickr
;D
dusty350
Hi
This build has moved on a bit since I last posted. It's a runner now, with a new, pattern loom fitted. Fired 3rd kick and sounds sweet.
I picked the paintwork up last week. Just need to fit the seat side strips, bleed the brakes and oil pump and it's done !
20210530_212357 by dusty miller, on Flickr
Dusty :wink:
thats wayyy to pretty for me to own. but i like it a lot. tasteful!!!!
mnein
2 Smoker
71R5JPAR
What are you running for wheels and tire sizes? Offset sprocket?
