Mat Oxley 1986 IOM TT
RD400E Special
Started by biggraham, March 19, 2019, 07:01:41 PM
If I had a 400, I'd be your buyer  :burnout:
biggraham
#31
Quote from: 85RZwade on July 26, 2021, 04:05:37 PM
If I had a 400, I%u2019d be your buyer  :burnout:
I just used them to help justify a Daytona frame and swingarm purchase..I already have said Bassanis, Daytona mags, a 400E seat, an xs650 front end and an rz rear end :olaf:
 :clap: I look forward to seeing that come together!
biggraham
Not sure about a mono shock conversion, but the rz swingarm weighs 4.5lbs , bare, before I remove 2 inches and  anything extra..
Daytona arm weighs 12lbs
(allegedly)
Wow, that's an amazing weight difference. I've replaced two RZ swingarms with FZ items because I thought they were heavy! Must be a lot of steel in the Daytona 'arm.
biggraham
Can't find an fz600 arm, they're 1lb lighter than an rz arm...
biggraham
Scored a FZ600 swingarm on eBay, on it's way :cheers:
biggraham
Here it is, not too shabby looking!
biggraham
Pretty sure the Daytona arm is lighter than 12lbs that I read, hoping to borrow a scale soon..
Debating punting the extra parts to get new tires, some machining and a motolanna swingarm...
biggraham
Pardon the gap in this build, life's been interesting for sure!
Mismatched wheels and tires aren't brilliant, so with a little detective work, it turns out thst a gs500 wheel has same axle size, and is already a 39 t 520 chain sprocket!
I also tracked down an aluminum swingarm, so let's see if it all fits together..
biggraham
Turns out they fit together beautifully, may not even need wheel spacers! It'll be great to have matching wheels, and ditch a front rotor and disc! I'll need a brake torque arm for the swinger, probably get one from economy cycle..
Wiring is pretty dire, anyone adapt a new 76/77 harness to a 78?
well isnt that nifty! very cool indeed.  :clap:
A MotoLanna swingarm?  Looks nice!
Quote from: biggraham on October 26, 2022, 03:31:46 AM
The only difference between the 76/77 and the 78 harnesses is the addition of the headlight relay on the E model (see attached)
