More swingarm swap - LC/RZ on AC RD350
Started by IR8D8R, July 06, 2026, 02:55:29 PM
Yamanatic
'Suppose a TZ750 swingarm would be a bit of overkill - a bit heavy but it's a stout muther! Discount price for 2SW:
 TZ750 Swingarm
Yamanatic
#17
Quote from: IR8D8R on July 17, 2026, 06:18:33 PMProbably a direct swap...
Width at the pivot is 200mm so is compatible. The advantages are the 4 roller bearings (side and shaft both), and the double-thickness arms spotwelded internally - that is why they are heavy. Builders from the day found stock arms the best for twin shock to mono-shock conversions due to their strength and rigidity.
The RD/LC pivot shaft would need a sleeve since the stock TZ750 is 20mm; easy fix. The complete axle with all spacers and adjusters and the caliper arm are also posted in separate listings and would make a nice kit:
TZ750 Axle Assembly
TZ750 Caliper Bracket
Discount price for everything!
bitzz
...but for that price you could have something custom made... that is a lot lighter
Yamanatic
Quote from: bitzz on July 19, 2026, 11:20:12 AM...but for that price you could have something custom made... that is a lot lighter
Just curious, how much cheaper and lighter?
So far, no one here has investigated the 2SW price, or asked the weight (consider, a TZ750 weighs the same as an RD250).
I HATE feeBay and their hassles/hustles, and price there accordingly. 2 different worlds...
Warren
im curious.  i def dont need an arm for anything but certainly eyeballed it. whats the arm length difference? not sure if it was mentioned
Yamanatic
Quote from: m in sc on July 20, 2026, 01:16:23 PMim curious.  i def dont need an arm for anything but certainly eyeballed it. whats the arm length difference? not sure if it was mentioned
The max functional center-to-center length (S/A pivot to axle) is 20"
Overall length is 22"
Distance from S/A pivot to shock eye is 16"
Weight with bearings is 12 pounds
W
Andrew S
I saw your TZ750 swingarm on eBay right away as well.  I'd love to 3D scan it for posterity, but I can't justify the purchase price for a project I'll probably never get to!
