The 2-Stroke Garage => Turning Wrenches => Topic started by: Fastash on May 23, 2019, 01:26:15 PM
Title: Has anyone used the VHT high heat clear paint?
Post by: Fastash on May 23, 2019, 01:26:15 PM
I'm kinda wanting to leave my new specII pipes in the raw and wondered if anyone has used VHT clear with any success? Thank you in advance. Ashley
Title: Re: Has anyone used the VHT high heat clear paint?
Post by: Hawaii-Mike on May 23, 2019, 03:55:51 PM
Yes it works well.  As with other paints, you want the metal to be clean and oil-free.  When my pipes start rusting, I sand the rusty parts, clean them up and reapply the clear.
Post by: Fastash on May 23, 2019, 05:15:21 PM
Thanks Mike!
Post by: pdxjim on May 23, 2019, 07:18:57 PM
Mop&Glo is way easier, doesn't flake or peel, and is easy to add another coat when needed.
Post by: Fastash on May 23, 2019, 08:41:48 PM
Quote from: pdxjim on May 23, 2019, 07:18:57 PM
are you speaking of the floor stuff? Please enlighten me.
Post by: Seizer on May 23, 2019, 08:49:13 PM
Quote from: Fastash on May 23, 2019, 08:41:48 PM
I take my pipes off, wipe them clean with denatured alcohol. Then hang them up in the garage. PourMop-N-Glo into a spray bottle and spray until coated. I usually do 3-4 coats. Looks great, smells great.
Post by: AAAltered on May 24, 2019, 03:54:55 PM
FYI, here are some Mop N Glowed Spec Ii's...
(http://i239.photobucket.com/albums/ff131/aaaltered468/023e11c77142f34e9db66f8db0ce4b5b.jpg) (http://s239.photobucket.com/user/aaaltered468/media/023e11c77142f34e9db66f8db0ce4b5b.jpg.html)
The top pic is a fresh coat, the bottom pic is after some running period...
(http://i239.photobucket.com/albums/ff131/aaaltered468/8ddd10ffe0f99b5b3cc7f2ab91cfc522.jpg) (http://s239.photobucket.com/user/aaaltered468/media/8ddd10ffe0f99b5b3cc7f2ab91cfc522.jpg.html)
Post by: pdxjim on May 24, 2019, 05:19:31 PM
Spray bottle or rag.  Doesn't really matter how it goes on.
(https://i.ibb.co/N2PGn0v/TDR-pipes.jpg)
Burns in a nice bronze color.  This is after a few years only one application when the pipes were new.  Reminds me I should pull em off and wipe em down again.
(https://i.ibb.co/QYRnJ4t/TDR-2-T-2019.jpg)
Post by: Organicjedi on May 25, 2019, 12:10:59 AM
Clear ceramic coating is another option if you want something more permanent. More spendy though.
Post by: Tuck on May 25, 2019, 12:37:49 AM
I just wipe mine down with WD40 couple times a month.  :twocents:
Post by: pdxjim on May 25, 2019, 03:23:49 AM
That sounds cool, but I'm not sure I could handle the service intervals on that program.
Post by: Tuck on May 25, 2019, 04:11:30 AM
Ya, its really hard to do... you better not try it.
Post by: Fastash on May 25, 2019, 10:44:12 PM
you guys are awesome thank you for all of your input !
Post by: quocle603 on May 26, 2019, 07:42:34 AM
Always expect the headers to go first, the paint will not hold up under the high heat
Post by: ~JM~ on May 26, 2019, 09:49:33 AM
I used either VHT or Duplicolor clear on an aluminum Edelbrock intake manifold. Manifold had been bead blasted & cleaned prior to painting. The paint held up well, but began to discolor with age.
