Re: The Best Possible Transmission Oil
Started by Jessup, March 14, 2019, 07:14:52 AM
Jessup
Could've been answered in one sentence: Type F auto transmission oil
Facts are more credible than marketing blurb
It's on the internet, it must be true :whistle:
Got any facts to back that up?
I use automatic transmission in mine, but I also do that because I'm cheap and my gearboxes don't see hard conditions. And with stiff clutch springs and in spec plates my clutch tended to slip on gearbox oils. Also, since my RD like to mark it's territory the red is easy to identify.
~JM~
Quote from: Jessup on March 14, 2019, 07:14:52 AM
What is the shear strength of Type F ATF?
bitzz
I just want to add; If you're using gearlube be sure to use GL4 rated for the yellow metal in the trans.
Kawi triple guys recommend Supertech 80-90w gear oil dino (not synthetic) sold at Walmart.  I've been using it on my triples for years with zero problems.  Maybe not the very best but for cost/benefit it's great.
I run nothing but Lucas 80\90 in all my 2 stroke transmissions for thousands of hard street miles. I have never had an oil related failure .
I run only Bel-Ray Gearsaver
Following the advice of a very wise man who told me back in 2010, "Bel-Ray Gearsaver 80w for street (75w for race bike)"  8)
Jessup
Quote from: ~JM~ on March 14, 2019, 09:28:31 AMWhat is the shear strength of Type F ATF?
Strong enough for drag car transmissions, and giant quarry dumper truck transmissions.
Jessup
For the past 5-7 years or so, I have used Rotella T4 in all my bikes.
No issues and only like $12 a gallon.
I'm sure proper gear oil is better, tho.
Quote from: SoCal250 on March 14, 2019, 03:49:05 PM
I'm with you Russ, I only use Bel-Ray 80w in all my streetbike builds...except in the race bikes I use 75w for the most HP I can get.
I have best R&D Motorsports race prepped trannys and when you spend $600 on this, the most expensive oil is cheap!
Ed, if you want the tranny to last, just use the belray 75W. I changed my transmission oil every 2 race weekends. (200-250 miles)
I put 3 years of hard road racing on my transmission without any failure's.
In some of our dog box and sequential race cars, all with dry clutches mind you, we have run some fancy Roush 0 weight oil. The performance is there, longevity isn't much of a concern as we operate about 20% under maximum loading and stacks are replaced at the first sign of depredation. I assume it would perform well in an RD as well. I think the ultimate oil is going to be highly dependent on what you are trying to achieve.
Quote from: SUPERTUNE on March 14, 2019, 11:46:07 PM
Hi Chuck, I think you know the "very wise man" I referred to in my previous post!  ;D
oxford
I used type f in my KTM 200 with no issues.  I am sure that transmission took way more abuse than a rd trans does.
forexer
#14
Great Stuff and worth the money  :thumbs:
