general babbling about master cyl and the single blue or gold dot caliper
Started by m in sc, July 22, 2020, 05:27:10 PM
So,
I have 2 rds running single yamaha calipers, one blue dot, one gold dot. In the quest to find that good lever feel, ive tried a bunch of different units, 12mm, 13mm , 10mm, 11mm.
from what -I- have found, the 11mm master from either a KX85 or YZ85 (nissin) seems to be the -perfect- ratio for these setups with a stainless line and a big rotor. only downside is slightly shorter lever (which i actually like) and no brake switch.
However,
you can get a banjo bolt brake switch. this takes place of the bolt, has 2 wires, and bam. done.
I used a grom master for a while, and while good, was a bit wooden for my tastes, as was the KTM390 duke one.
Just passing along some info. hope this helps somebody. I have found them for 130 ish, i think the KX ones.
oxford
For reference, do you know what size the Grom and Duke masters were?
Years back after a lot of research on blue vs gold dot calipers, I found the difference was that the gold dot has aluminum pistons internally vs steel ones in the blue dot ones.
Frank B did the research when we did our conversions and found out that a Yamaha Zuma Scooter has an 11 MM Master Cylinder. I bought one used on flea bay for $30 shipped if memory serves. It comes with a brake light switch and bolts right on. They work perfectly for this application.
url=https://postimg.cc/WFFRBByw][/url]
pretty sure the grom and ktm ones are 12. not sure.
good note on the zuma one timmy, you told me that, i completely forgot that.  :patriot: :cheerleader:
retaRD
I'm running a single silver dot with a Duc 320mm rotor, braided line, and a Yamaha warrior master (four wheeler).
I haven't felt better brakes on another single rotor bike.
I like the Ducati 320mm with bluedot 4 pot R6 caliper and the XS400 14mm master.
Just did a this setup on Paul's STG 2 '76 RD400
I am surprised you can use a 14MM master cylinder with a single caliper. Mine was very wooden feeling with a 14 and marginal at 12. That's why I went on the hunt for an 11MM. That being said if it works that's good.
I'm running a 12mm EX300 master with blue spot caliper and 320mm disc on my TDR.
Feels great and night n' day difference to the stock setup.
i was pretty ok with a 12, like the 11 more, just my .02 preference.  fzr rotor though.
Organicjedi
Quote from: Kawtriplefreak on July 25, 2020, 11:11:58 AM
The stock MC on a US spec RD is over 15mm (5/8) with the single stock caliper. Wooden? A bit. 14mm would be an improvement. Not enough for me to change it though. I would if I ever had to replace it for some reason.
I'm sure the feel would be a lot worse with a blue dot and the MC would have to be changed. Glad all you guys have done the experimenting already.
actually a lot of people prefer a 13 on a stock rd caliper. I tried it didn't like it, prefer a 14. have a 12 on the rear on on the lc, gives really good feel with a much shorter brake lever.
:twocents:
FWIW, the Yamaha "...dot" calipers have a bit snakker pistons than the equally available Brembo 4 piston calipers (34/34), so work better with a small MC. Stock RD calipers, as well as Brembo work great with a 13 mm MC
