Rear brake problem - RD400F
Started by SoCal250, October 05, 2020, 11:55:03 PM
Hardy
Thinking simple still, perhaps your new line has been over crimped? Only way to test would be to remove and push air through it...
Hardy
Quote from: Hardy on October 25, 2020, 02:41:10 AM
The brake hose is not new. It's the same braided SS one that has been on the bike since I have owned it, and the brake was working fine with this hose prior to rebuilding.
forexer
since you're not sure what the problem is I would do exactly what you did and troubleshoot one component at a time.
after re- reading - the only thing that hasn't been checked is the brake line itself and although you say it's good I would definitely check it and verify that it is in fact good so you can rule it out or if it's found bad change it.
Good Luck!
