The Featherweight Monospine
Started by m in sc, February 13, 2019, 01:46:59 PM
Christmas day ride, 2018.  Man this thing runs sweet. (chucks porting does wonders  :righteous: )
was testing out the V Force reeds and making sure the 3-d printed tailight held up. white sip ties were until epoxy dried holding led strip in.
~JM~
retaRD
So when is this thing gonna have rotobox carbon wheels?
As if it needed to be lighter...
the 17mm titanium bar is on its way, have the 15mm already. axles. (drop ends will be used for spacers, etc) :whistle:
Seizer
Gonna get some Carbon-Ceramic brakes? That's gotta be worth a couple of pounds.
Tuck
When I weighed a bunch of conventional forks a few months ago FZR400 were the lightest by quite a margin and with an alloy stem and/or alloy bottom clamp, they could be even lighter. I have a modified GSXR stem in a set of RD350 forks on the drag bike.  That saved a bit.
Might be worth looking at a modern small bike for even lighter/stiffer forks.
i was actually talking about this 2 nights ago. I will probably go with an aluminum stem and a billet lower tree eventually, but im keeping the stock forks, they work very well with the setup and emulators in them. I mean, im over 100 lbs lighter as it is.  :whistle: if i can hit in the high 220s/low 230s i'd be blown away. (im in the 238 ish range i think, maybe less with fuel) after the axles i'm going to weigh it on a certified scale.
Gill
Mark, which speedo did you opt for?
Frame band swingarm is a masterpiece.
thanks, Danny did a hell of a job on that frame.
I used a trail tech endurance. some of the models can be powered by AC voltage, or DC. I needed that because all the power on that bike is AC, because, wiring and junk is heavy.  its really good, and it automatically backlights when the bike runs.
https://www.trailtech.net/endurance
interestingly, this jut got posted on FB by allen tucker. hadnt seen this pic before, but the yellow bike in the pic was basically 'V1" of the lightweight bike , a modded stock frame i built out of spares. I think it was about 35-40 lbs lighter than than a stocker. left to right: cody, me, pete. 2010
stresa
Hi Mark,
who was the manufacturer of the fuel tank on the yellow bike? I have exactly the same lying around for years.
Regards Uwe
81 Jackson Special 250, 2x 74 Yamaha RD250 racer, 78 Yamaha RD400, 72 R5/RD350 rat, 74 RD250 streettracker, 76 RD250, 72 DS7, 75 Yapol TZ250, 89 Honda RS125,
80 Hejira TM250, 77 Höpfner-TD3, 76 RD/TD3,
74 Yamaha TZ/RD250A, 78 Siroko TZ250, Tomic 200, Heideveld RD375 3cyl
i dont know. i got it with a bunch or parts years ago, was relatively heavy fiberglass unit. neat tank though. Lined it and never had an issue. Made a strap to mount it though, was kind of a PIA.
