First start of rd400 right side drowning?
Started by rd400greenhorn, April 25, 2021, 12:40:13 PM
rd400greenhorn
Hi guys
So first start of my rebuild bike. Complete rebuild engine
It started right up byt it seems like the right hand side dont really fire or sometimes there is smoke and the Nothing.
Also starting dripping at one point from the pipe? With fuel
It starts right up but yes, Any suggestions
Does the carb throttle slide? Sit a bit low?
Arrow
That carb slide is the wrong way round.
Arrow is correct.  Slide cutout faces rear.  Most likely you've switched R and L slides and both are backwards...
Arrow
Is that carb bowel wrong too? I thought the elbows should face each other, on the inside, not the outside.
rd400greenhorn
Ive changed the slide on the right carb so now its cutout faces air filter.
The left side carb was correct
It still has problems
Maybe tomorrow i Will varify they have correct floating bowls
Tips are welcome 😁
Arrow is correct. That float bowl is on the wrong side. It looks like you have them swapped on the bodies.
Arrow
#6
Quote from: SoCal250 on April 25, 2021, 07:00:55 PM
I suspected this, but wasn't 100% sure on that one. Long time since I owned one of these bikes.
Arrow
#7
Quote from: rd400greenhorn on April 25, 2021, 06:41:29 PM
Tips are welcome [emoji16]
This may confuse the situation and not make much sense at all to people reading.
We have communicated today and the original poster has more than one set of carb. slides.
Forums are great, but sometimes confusing.
It's a massive bonus if we can eliminate some of that confusion.
