RD400 LED Headlight
Started by Milan, August 09, 2021, 07:38:08 PM
Milan
I have been wanting to put an LED headlight in the RD.
My headlight has the fixed bulb.
I looked in the parts book & found other headlights that have replaceable bulbs.
So i found one in Ebay.
Bought a bulb off of Amazon.
Bulb does not fit correctly into holder.
It falls thru.
M
Milan
LED on rim
Milan
Adapter & bulb fitted
Milan
All together
Milan
Bulb used
You should add some details of parts you used. It will help out others who may want to do this mod. :thumbs:
What Yamaha model did the headlight lens assembly come from? Is it the same size lens as the RD400?
Are there any depth problems in the bucket? Does the adjuster still work?
Milan
This is the headlight that was purchased:
https://www.ebay.com/itm/283009483458?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
For as XS400.
Same 7" size, but it had the removable bulb.
I have not mounted it yet, but seems like it will fit in the same headlight rim, with same adjustment.
The 400F parts manual also shows other part numbers for the replaceable bulb headlight lenses.
So it could be considered a stock item, as to keeping the bikes authenticity
This is the bulb:
https://www.amazon.com/gp/product/B08BC4G48W/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Milan
This is the adapter.
I got some extras, if someone else wants to try also.
M
the only issue you may run into it it clearing the back of the headlight bucket. But ive converted almost all my bikes. on the r5, i actually soldered a male headlight plug with wires off the back of the bulb on to allow the factory plug to be set to the side.  But, i think 400 buckets are deeper so you will probably be ok.
Milan
Old headlite
Milan
New headlite.
Hi & Low
How is the light pattern? A two-sided LED setup like your bulb is probably the closest to the original halogen filament layout. I put a very cheap three-sided LED in my GL1000 reflector, and was surprised that although the high beam lights the trees, low beam gives a good flat beam with a sharp cut-off.
Milan
Have not had a chance to examine in the dark.
I will post after i see.
M
