Top end knock
Started by Joshua, March 13, 2022, 08:04:06 PM
Joshua
I had a reputable guy build my motor a while ago. Finally got it legal and took it for a longer ride and when I got back home I noticed some top end knocking. I maybe have 3-4 tanks of gas run through it, so not that many miles on the bike yet. I did have the timing slip, so I reset the timing on it.  Just looking for feedback on where to start. It's super disappointing as I haven't even got to enjoy the bike and I'm afraid I'm already troubleshooting problems. My builder has not gotten back to me, so I think he may be MIA. Thanks for any feedback you guys could give me.
https://youtube.com/shorts/APU7rufTpWY?feature=share
Arrow
What ratio premix are you using?
Joshua
16oz to 5 gallons of gas, 40:1.
Arrow
Ok. That should be alright as long as there is very little full throttle use. The pump kicks out about 20:1 after the 3/4 throttle position.
Sounds like a partial seizure to me. Could have been an air leak too...
If you are sure the noise is from the top end, I would do a leakdown test first to check for leaks. Check what the plugs look like and then pull the head and take a look inside.
almost sounds like a small end bearing, but could be a partially collapsed skirt.. id pull the cyls & see whats up.  :twocents:
Clean build. I would inspect everything. When he built your engine, was it both the top and bottom end? What did he replace?
Joshua
Thanks guys. You all know my builder, just don't want to throw him under the bus for something that happens on a crappy day. He built it from the ground up so every piece was touched, replaced, ported, upgraded, new. I know he has been MIA, but he typically would get back to me if I called or texted him, hoping he is alright.
Make sure you check squish clearance. Could be as simple as a wrong thickness head gasket.
Washerman
Piston slap maybe pull the pipes and take a quick look inside there.
Agree with the others and lift the cylinders off, then post some pictures if you need help figuring out what's up.
Sounds like what mine did when it ran on little oil. Pull heads and look.
Joshua
Thanks all. I'll pull them in the next few weeks and update. Appreciate this community, wouldn't have gotten the bike done without everyone here.
Wow. Riding season starting up in Florida. Just use a large portion of patience and get it right before setting yourself back for the summer.
Quote from: Joshua on March 15, 2022, 12:03:56 PM
Wow, you have a lot of patience. I would have had my motor apart within minutes of getting it home. I would just have to know what went wrong or it would bug the s**t outa me.
