Rd 350 leak down test fail
Started by Rgvnfla, March 26, 2023, 12:05:04 PM
Rgvnfla
Hello fellow strokers,
Just completed,I thought, a rebuild of my RD and it failed the leak down.
I can hear and feel air coming out of the other cylinder exhaust port, pretty sure the case are sealed well with 3 bond. Maybe labyrinth seal ? Just thought I would ask for opinions before I split the cases again. Thanks in advance for any help
Brad-Man
#1
Leakdown test involves sealing all intake and exhaust ports and seeing if crankcase holds pressure - labyrinth seal of no concern.
1974 RD350
1975 RD350/400 project
1985 BMW K100RS
"Seal" is almost too strong a word for what a labyrinth seal does; impediment, or maybe resistor would be more accurate. Plug those exhaust ports up and try it again  :thumbs:
Rgvnfla
Oh I see, thank you gentlemen
Rgvnfla
Yes sir that's where my mistake was , didn't seal the other cylinder.
Thanks for the help
ajb
Great, hope it goes well.  I just did a test on my RD400, phew, all good!
Rgvnfla
So leak down is behind me now , passed with flying colors.
Held 6 psi for 10 minutes without even a tenth psi of drop. In the frame it goes ! Thanks again for the heads up [emoji1690]
