Fork Seal area Broke - Any Hope ?
Started by KANDY, April 06, 2023, 09:34:02 PM
KANDY
Hi All,
RD350 Outer Tube seal area broke while removing the seal. Any hope for me to correct this
Please give your thoughts.
Thanks
1974 RD350
new fork leg lower is the only fix worth doing, or would have to be welded up and shaped on a lathe. man, that sucks. and don't use a pry-bar to pull it out like that. if you do go easier. is the seal area affected all the way down?? if not, you can use it the dust cover will hide it and -maybe- use some case sealant behind the seal there if its making at least half contact but i would give that a 50/50 chance of working.
I agree. Maybe clean it up real good, put the seal in and fill the hole with JB weld. Still taking a chance though, especially if it encroaches on the sealing area.
Worst I did was bend one up bad enough the seal wouldn't seat straight. Still replaced it with another fork leg though. Sorry that happened!
The Red Scourge
It looks like it's the dust seal area, but could let moisture and road grit into the actual seal area.
'76 Yamaha RD400C
'71 Kawasaki G3SS
'88 Honda CBR400RR
'90 Yamaha FZR400/600 hybrid
KANDY
1974 RD350
id use case sealant, moto seal. it will leech in and give a little.
worth a shot. I'd try it.
There are a couple sets of fork lowers on ebay right now.
KANDY
Sorry, idid not updated here.
Bought one set from ebay already. Waiting to arrive.
Can someone explain the fool proof method to remove the Fork seal.
1974 RD350
