Yambits piston performance and quality
Started by RD350NL, March 15, 2025, 03:20:30 PM
RD350NL
Hi all
I have used the Mitaka (skirted) pistons yambits sells with good experience in the past. I am now seeing these pistons have bigger inlet ports compared to the version that doesnt have the tang.
Is there a difference in performance and quality?
I am boring my cylinders to 65.00 and it looks like only the pistons with smaller inlet windows are available in this size.
Without tang and smaller inlet window: (is this even Mitaka?) https://yambits.co.uk/rd350-piston-kit-100mm-p-53222.html
With tang and larger inlet windows:
https://yambits.co.uk/rd350-piston-kit-075mm-p-8150.html
They are all Mitaka pistons. This is the one to use if you want 65mm with the bigger holes. RZ piston. https://yambits.co.uk/rz350l-piston-kit-100mm-p-15912.html
RD350NL
Thanks for sharing, as far as I know I have the original porting. Will the bigger holes make a difference?
Quote from: RD350NL on March 15, 2025, 04:06:20 PMThanks for sharing, as far as I know I have the original porting. Will the bigger holes make a difference?
I think so, less of a restriction as it is inhaling.
RD350NL
I see the difference. I am wondering about the performance part, shouldnt have yamaha put the bigger holes in the OEM pistons if they performed better?
The Red Scourge
Quote from: RD350NL on March 15, 2025, 05:05:14 PMI see the difference. I am wondering about the performance part, shouldnt have yamaha put the bigger holes in the OEM pistons if they performed better?
Maybe to help with emissions and/or gas mileage.
'76 Yamaha RD400C
'71 Kawasaki G3SS
'88 Honda CBR400RR
'90 Yamaha FZR400/600 hybrid
the holes are mostly there to act as tranfser port (boost port) pass through windows while the reed is shut and the piston is coming down. for example, look at wiseco ones. they are just holes.  0.02
2T5
Would smaller cut-outs mean a stronger piston? Less chance of failure?
RD350NL
I have them in and they perform the same as the LC pistons.
