Question on Sprockets for RD350
Started by captainslow, June 01, 2025, 11:33:09 AM
captainslow
:wave:
I am looking to install a 15/37 sprocket set for my 75 Rd350. Will the US 1979 Daytona std 15/37 be a straight fit? I understand that that bikes had spoke/alloy wheels but not sure if the clutch hub dimensions are the same.
p.s.: The 350 has a 400 transmission installed which has a closer ratio 4/5/6.
TIA
The rear sprocket bolt pattern is wider on a 400 compared to a 350, if that is what you're asking.
captainslow
Quote from: m in sc on June 01, 2025, 05:13:12 PMYeah, wont work unfortunately.
Thanks for confirming.
Quote from: 1976RD400C on June 01, 2025, 05:04:57 PMThe rear sprocket bolt pattern is wider on a 400 compared to a 350, if that is what you're asking.
Thanks for clarifying. Yes that's what I am looking for.
