R1/R6 RD350 front disc conversion questions
Started by Scuffed98, September 10, 2025, 06:29:41 PM
Scuffed98
Sorry if this has been covered a million times already.
I found the info about converting the front brakes with R1/R6 components. So does the R1/R6 rotors just bolt on to the stock rims or do I need spacers/adaptor plate to make it work? Does it matter what year of R1/R6 I take the brake components from? Would it be fine if I ran the calipers on the stock location or do I need to mount the caliper rearward? I would like to retain my stock speedometer if possible.
'74 RD350, 78 Peugeot 103
you can run it forward. you need the adapter, and an fzr600 rotor, and any blue or gold dot caliper.  would highly recommend a 12 or 13mm master cyl (a grom or zuma ones works nicely)
Scuffed98
Does the FZR600 rotor need a spacer or can it just bolt straight on?
Quote from: Scuffed98 on September 11, 2025, 01:16:03 PMDoes the FZR600 rotor need a spacer or can it just bolt straight on?
A spacer is required. 80mm x 6 bolt circle
You'll also need:
Rotor bolts, longer - 6pcs
Caliper mounting bracket, custom
Caliper mounting hardware
Scuffed98
#4
Do you know how big the ID and the OD need to be on the spacer?
Quote from: Scuffed98 on September 11, 2025, 02:16:53 PMDo you know how big the ID needs to be on the spacer to fit on the hub?
I used 64mm ID, 109mm OD. The FZR rotor is about 63.8mm ID
Mine was mounted on a Daytona 2V0 wheel, but everything is the same as on the RD250/RD350/RD400 except for thickness.
Scuffed98
How big does the bolt holes need to be for the hardware.
Scuffed98
What length and grade for the caliper and rotor bolts are recommended?
Thanks for all the info. I don't have any of the components on hand so I couldn't take measurements myself
i honestly dont remember off the top of my head.
SDDaytona
Quote from: Scuffed98 on September 11, 2025, 02:16:53 PMDo you know how big the ID and the OD need to be on the spacer?
You could make one but the easiest way is to unbolt the center section from a stock RD disk and cut off all but the center portion.  Spaces the FZR rotor perfectly
send the dxf files i posted to xometry, they are a mail order cnc service. 6061 aluminum
https://www.xometry.com/
I used Send Cut Send sendcutsend.com/
US made, choose your material, delivered in a few days with free shipping. It was about $38 for the last 6061 0.500" spacer I ordered. And I custom designed it right on their site with my dimensions. You can also upload design files.
A big thanks to the late Julian Farnam (Frame Maker) and to Ken (kpke) for introducing me to this great resource a few years ago. :thumbs:
I can machine these things in shop and unless im in a hurry I still use Send Cut Send or PCB Way. Materials costs are such that even when I get good deals I can't do it myself as cheap. A good 3/8" end mill is $20. Material another $10. Then an hour to machine. Might as well upload my file and go about life as somebody else makes it.
