RD-RZ history
Started by teazer, July 05, 2019, 08:15:24 PM
Quote from: Jspooner on July 11, 2019, 04:50:08 PM
Quote from: motodreams on July 11, 2019, 04:22:01 PM
Are there any side covers that are interchangeable with the RD350LC?  Maybe a RD400?  I am still looking for a solution for the hard to find clutch actuator mechanism missing on my LC...
Yes, RD400 fits perfectly, you just have to make some room for the electronic ignition trigger for the LC. Ill take a pic of mine and post it in a bit.
Was that an RD cover with TZ (replica?) rear cover and ignition cover?  Nice way to get a TZ side cover. And for anyone that prefers the vertical mid-mounted RD type clutch cable, they can cut a slot in the crankcases.
Nice research Ed.  I'll send you some pictures of different crankcases as soon as I get them into some sort of shape.
If anyone has pictures of Euro RD250 c-f cases (bare) that would be great to see them.
Quote from: teazer on July 23, 2019, 08:09:00 PM
That's exactly what it is.
EE
Alright so I was going to add Cylinder stud lengths and just got the "you cannot exceed 20000 characters!!!!" messaged so I cleaned things up a bit and i'll try to post the new compilation in the next post..
EE
History and differences between RD250,350,400, 73-80 TZ, LC, and RZ engines
(from the 1970 DS7/R5 to the 1990 reverse cylinder TZ250)
(Note: for ease of reference I refer to 73-80 TZ's as "early TZ's" because the cases interchange)
-1962 The RD56 Yamahas first World Grand Prix Champion winner (56x50 rotary valve 250)
-1967 The YR1 Yamahas first horizontally split parallel twin (61x61 350 / 2 tranfer piston port cylinders)
-1970-1972  DS7/R5 start of the 4 transfer  port cyl base/cases layout that form the basis for the RD and early TZ  series
-DS7 / TD3  250
-R5 / TR3    350
-TA250 early 1973 aircooled TD3/TZ hybrid
-An interesting point: The some of the "works" TR3 engines from 1972 sported 6 transfer ports, like an F/G model 350.
-1973-1980 TZ's used a variant of the "RD" cases but used Piston ported monoblock watercooled cylinders
-The TZ250 G in a last ditch effort to get ever last hp out of the "RD" based case engines ran an intake so big it became know as the piston eater..
-In 1981Yamaha totally redesigned the TZ250 engine. Having reached the limit of intake port size in the G, the H models crankshaft rotation was run backwards to put piston thrust on the cylinder wall opposite the intake allowing further increases in intake port size. The cylinders were now individual but still piston port. Also new was Yamaha's exhaust power valve system which in it's infancy was having teething problems.
-In 1985 Yamaha again Redesigned the TZ250 engine. 1985-1987. Switching for the first time to case reed induction allowing for much needed transfer area (2 new boost ports were the intake once was) creating needed bottom end & thereby also a wider powerband. BUT 1985's reedcages were to small and were quickly enlarged.
-In 1988 through 90 in a last ditch effort to get every last hp out of the parallel twin design Yamaha reversed the cylinders & tilted them forward to 60deg putting the carbs in front & the pipes coming straight out the back under the seat.
-Because the R5/DS7 was the first Yamaha to have the 4 transfer port cylinder base case layout (2 on each side with a 5th boost port added in the RD series) RD, LC and early TZ cylinders will bolt directly onto the R5/DS7/RD and LC cases.
-though you do need to use the correct cylinder stud lengths (Teazer)
-BUT the R5/DS7 only had a 5 speed though it's super easy to swap out the gears, shift forks and shift drum for an RD 6 speed setup (gotta love Yamahas parts interchangeability!)
-TZ cases were a separate casting than RD cases yes a very slight variant but still a separate casting, so close though in fact when TZ racers broke early TZ cases it was super common to replace them with RD cases.
-TZ cases differ from RD cases in that:
the front engine mounts are rubber mounted,
There are grooves to locate the TZ crankshaft cut into the crankshaft inner bearing area to locate the crankshaft there instead of from the primary side bearing because the TZ's used a different crankshaft (that will interchange if you cut the grooves in RD cases) that used Roller bearing mains on the outer ends.
-There is an oil passage below the shift drum not "drilled" on TZ cases between the transmission and primary gear sections of the case and the kickstarter boss has a plug in it (Yamaha part number 90338-17016 BH) (Teazer)
The oil drain is in the middle of TZ cases but offset one the RD cases. The center RD crank bearing surfaces normally have a cast in steel insert and the TZ cases normally don't. BH
so TZ cases were more than just RD cases machined for front engine mounts.
- Early TZ's had a different transmission, though it would drop right in RD cases it has a VERY tall first gear and much closer gear ratios with a longer mainshaft to allow for the TZ dry clutch.
-The TZ dry clutch if combined with the TZ transmission or an RD transmission with a special mainshaft will bolt directly into an RD
-A TZ dry clutch with a special mainshaft will bolt directly on to an LC
A TZ dry clutch (with a special mainshaft) and slight modification for gasket sealing to the cases will bolt onto an RZ.
-DS7/R5 cases had no grooves in the crankshaft seal area to secure the seal as everything RD and later does. And they did not have the mainshaft clutch side bearing retainer behind the clutch.
-According to the aircooled RD club early RD400 Prototypes had solid mounted engine mounts!
-RD400 cases have slight differences in the castings, the earliest had a little less material around the cylinder base gasket area at the rear and more ribbing around the right main bearing for sure (and right transmission mainshaft bearing if memory serves me correctly) in later cases.
-Starting with Daytona in the US and later UK cases used a different kickstarter mechanism. Daytona could use either kickstart mechanism, I "was told' back in the day that the gear on the "Daytona style" kickstart mechanism which on this new design was not constantly engaged with the idler gear like the earlier mechanism is in racing had slid over and engaged on some racers so common practice was to retrofit the old system when using "Daytona' cases. I did have one customer that would not take no for an answer so I used a throttle slide return spring to keep the kickstart gear positively disengaged when not in use. One drawback with the "Daytona" style kickstart mechanism was that it kicked over more slowly as well. This style also used a "single" offset idler/tach drive gear instead of the 2 gears pressed together of the earlier style since it drove the tach.
-EarlyTZ's used this gear also but ran it with a neeedle bearing. Later RZ's used the "single" gear but added a bushing to it.
-Since Daytona and later RD's used the single gear kickstart idler gear they used a longer tach drive shaft and internal gear ratio in the case right before the cable, also a smaller tach drive nylon gear
-TZ250 and 350 had different primary gear ratios than the RD's so they used 2 different nylon tach drive gears (and 2 different water pump drive gears)
-While the rest of the world got electronic ignition in 79/80 we didn't here in the states..
-The Daytona, got a new crankshaft without the dreaded lead weights but improper heat treating it's believe causes them to snap the center section under racing conditions..
-Later UK RD400 and RD250 did get this style of crankshaft though with the larger LC/RZ style ignition taper for the electronic ignition they got but I'm told those did not have the racing center crankshaft snapping problem.
-LC's went a step further and went to the now well know RZ/Banshee style crankshaft but the LC's still had a 16mm wide big end bearing (RZ widened to 17) with large big end and wrist pin bearing outer diameters.
-An LC crankshaft will fit in Aircooled RD cases, but you need to mod the end of the crank, OR 'doghouse' the RH cover to take the longer crank. (no oil pump can be used after this mod) the LC crank also allows for a large taper cdi to be used, and yes, an rz or lc cdi will then bolt right on to aircooled cases. you will need to clearance the LH cover to accommodate the cdi pickup though.
-An RZ crankshaft is a mm too wide to drop right into RD/LC cases but have been made to fit.
-The keyway on a Daytona crank is 90 degrees off the LC and RZ cranks
-RZ cylinders while they would work on RD case have a much different cylinder base stud pattern, but the cylinder center to center spacing and heights are the same as a RD and LC 350 they will "slip in" they just won't bolt up
-The RZ right side cover/water pump will not work on an RD set of cases because they are missing the rear water pipe passage and the boss to support the pump shaft.
- RZ and LC have a longer right crank snout than an RD to take the water pump drive gear.
-Some have used the wider RZ rods in RD's on RD cranks by machining .5mm off the inside of each crankweb.
-An RZ clutch cover will almost fit onto an RD set of cases but the RZ have a little more metal in two places. Teazer
-An RD clutch cover can be made to run a TZ water pump, the TZ waterpump will be driven through the original oil pump drive shaft hole, but it does require an adapter to fit under the pump.
-LC and RZ use the same kickstarter arrangement/mechanism. Similar to the Daytona and later UK RD's On the RZ/LC the inner end of the short kickstarter shaft is a smaller diameter than RD's, so either the cases needs to be bushed or a sleeve pressed onto the shaft. The shaft is longer than an Air cooled motor which is fine if you use an RZ clutch cover. This can only directly be done on Daytona and later UK cases as there is a different style locator spring boss in those cases (unless of course I suppose you weld and machine one..)
-The RZ/LC kickstart shaft is considerably longer than RD's, twice to use an LC side cover I grafted two early style RD kickstart shafts together to extend them  17mm.
-LC and RZ transmissions use three shift forks and not 4 as in the RD's
-Unlike the RZ, LC's still had the clutch pushrod that went all the way through and out the left side of the cases to a clutch actuator in the left side cover.
-You can run RZ/Banshee primaries on an RD I've done it a number of times
-The Daytona and later left side covers had a provision for the electronic ignition pickup
-The Daytona had thinner primary gears
-The Daytona 5th and 6th gears had thinner engagement dogs which made them easier to shift into these gears but not good for racing..
-The Daytona and later used a different shift mechanism ratio
-76-78 US RD400's had a small cutout at the bottom of the skirt on the exhaust side for emissions reasons that actually let ex gasses into the crankcase at TDC! the Daytona did not have this cutout because it used external exhaust butterfly valves between the cylinders and exhaust pipes for emissions reasons so the trick was to use Daytona pistons in all the 64mm bore RD's at least until RZ (and LC) pistons came out.
-76-78 US Rd400's also came with an small exhaust bleed port from the roof of the exhaust port tunnel to approximately 10mm above the exhaust port, in performance applications it's standard practice to plug and weld these closed.
-All year RD350's in the US had Dykes ring pistons (not good for racing...)
- An RD400 left side cover will fit an LC perfectly, you just have to make some room for the electronic ignition trigger for the LC. JSpooner
Here are some engine model differences between US and UK 250/350/400's from a European viewpoint. 5Port
R5/DS7 Cases sometimes do have the shallow recess for the early RD type crankseals.  No idea when that changed, just can be seen on some cases.
RD250/350.  Euro 351/352 models have a blocked 6th gear (different pawl plate in selector segment pins).  Different sprockets to raise final drive ratio.
RD250/350B.  Euro 521/522 models have 521 Model carbs, cylinderheads, gearbox and exhausts.  The gearbox has all 6 speeds available and has the same ratio's of the later 250/400 with overall closer ratio's and revised final drive ratio.
RD250/400C/D.  Euro 1A2 (250) and 1A3 (400).  Similar to 1A1.  Gearbox shafts have later type splines.  Cylinderheads are marked 1A0 (250) and 1A3 (400), different casting to 1A1.
RD250/400E.  2R8/2R9.  "TZ" style crank with no lead weights and slotted rods.  Revised cylinders, porting and CR. Revised 400 pistons without front cut-out in skirt.  CDI ignition. Revised LHS case cover with bulge over CDI pick-up coil.  Gearbox and shifter changes.  Narrow primary gears.  Revised carbs and small X-over tube on 400. Revised 2R8/2R9 big-bore downpipes and silencers.   5Port
-Banshees had different transmission gear ratios than the RZ most everything else interchanges
RD250/350/400 Performance Parts Upgrades
RZ350 or Banshee pistons are a far superior piston than the stock pistons.
Of the cast pistons OEM are arguably the best, then Vertex, then Pro-X
Of the forged pistons Wossner, then Wiseco
The center tab at the bottom of these pistons must be removed thought (very easy),
And Vertex must be trimmed a bit if used in an RD400.
For Racing Bigbore Topends (66mm and up)
1980 IT/DT 175 pistons or Yamaha Blaster Pistons. Either piston is 5-6mm shorter than stock and requires machining the top & bottom of the cylinder to compensate for the height. The blaster pistons also have a 10deg piston dome instead of the RD/RZ/IT/DT 15deg so it does require reccutting the cylinder heads (but if your doing a bigbore you need to recutt the cylinder heads anyway)
Sleeving these cylinders is not ideal because of the decreased heat dissipation from the pressed in replacement sleeve and the fact that the thickness of a replacement sleeve cuts into the already limited transfer port tunnel area.
But there have been some Extra Big Big Bore cylinders done with H2 pistons and sleeves. JR
The Crankshaft
For High HP applications Shot Peening the connecting rods is recommended
2T2 rods are the best of the OEM rods
Need Hollow crank pins? I use Kawasaki  13035-1010-01
Big End Bearings
I used TZ750 big end bearings in my landspeed bike but there were less options then.
93310-422BO "TZ125 big end bearings" Coyote
Suzuki RG500/RM125 bearings 09263-22060  Lyn
Suzuki RM125 RG500 Wiseco part number is B1047 Supertune
I use OEM RG500 Big End Bearings 09263-22060 for all out racing and Wiseco RG500 part# B1047 for EVERYTHING else. EE
Crankshaft Main Bearings
73-80 TZ250/350/750 outer roller bearings part number 93310-00012
but these days hybrid ceramic bearings are the way to go.
Exhaust Flange Gaskets
76-78 US spec cylinders use Suzuki 14181-01D00 They have a larger I.D.
A newer option though is to use Blaster exhaust flange gaskets. Supertune
Clutch Friction Plates
"1981YZ250H,1983 XS400, 1986 FZ600S, 1992 FZR1000D. XS400 plates work especially well" Dave
"FZR1000 friction plate have about 40% more surface area" M in SC Clutch
RZ350 (more surface area than the RD400 because they didn't use the large rubber "cushion rings" to reduce noise)
Steel Plates Earlier RD250/350 steel clutch plate didn't have "The balancing notches" so have more surface area or Barnett
The RD250/350 had a 6 plate clutch but that can easily be swapped out for the later 7 plate clutch
if you put an RD400 trans in an RD250/350 with the 400 clutch you will have to clearance the inside of the RD250/350 right side engine cover, or I've heard you can use a thicker side cover gasket.
There are different clutch and sprocket splines on the RD250/350 than the RD400 transmission.
RZ350/Banshee Clutch Basket and Primary Gears fit right on Rd's
Dry clutch conversion
I've heard that HB used YZ490 parts to do this conversion
TZ250/350.(Takes a little work) Use the clutch and primary sidecover. This requires a longer mainshaft, but the stock TZ mainshaft has a higher first gear than the RD's and is part of the main shaft so you can either run the TZ transmission with higher first gear and close ratios or get a special mainshaft from this company: http://www.yamaha-tz-classicracing.de/uk/teile_getriebe.html that allows you to use an RD transmission with the TZ dry clutch parts. The TZ dryclutch cover does not come with a provision for a kickstart mechanism but I have seen several of these covers modified to use a kickstarter. I've used a billet LC cover by Metemachex to due this with a kickstarter but you have to extend the kickstart shaft 17mm. NOW Fondseca makes a dryclutch cover with the kickstart provision..
Transmission
It is highly recommended for racing that you get your transmission undercut by a company like R&D Motorsports. R&D also does transmission micro polishing and anti friction coating.
Banshee/RZ aftermarket straight cut primary gears
"According to Yamaha service bulletin 259 any spinning gear should have between .003" to .005" side play for maximum efficiency. Too little clearance and it will bind, too much and the gears can pop out of engagement causing the dogs to become rounded. Select the proper size shim and install it so the spinning gear is moved toward the sliding gear that engages it. Sizes are 20.2x33x.5,.6,.7,.8,.9, and 1.0mm (137-17427-00-05). And also 25x34x.3 and .5 (168-17428-01-03)" LynReeds
-TDR RD and RZ single petal fiber reeds, if your extensively modifying your stock reedcages ask for the Harry Barlow cut it's a tapered reed that completely covers the reedcage surface area.
-1986 YZ125S reeds. "These are a 3-petal reed cut one petal off to fit your stock cages. Part number 55Y-13612-00-00" MBSteve
-Another option is the 93-2012 YZ85 reeds and trim them down just slightly at the front. These are a single petal reed but thinner than the TDR petals. Part# 4ES-13613-00-00Reedcages
Your options are:
-Modify your stock reedcages, this works great for 80% of the RD's out there, Stock cages are good for up to 70hp.
-YZ85 reedcages
-V-Force replacement cages for the RD reedcage which also fit the RZ500, and YZ85. Part number V382A (Use AG472A stuffers) Afhaldeman
-RZ350 reedcages
-RZ350/Banshee V-force replacement cages
-Or my favorite stock YZ85 reedcages with either stock reeds or TDR racing reeds part# 88-EE or V-force YZ85 for 90 percent of RD applications
Anything bigger than this and major surgery to your cylinders or replacing the whole intake reedbox is required.
Intake manifolds
RZ350 are a nice improvement and allows you to use an intake crossover tube or boost bottle. You can also get aftermarket RZ manifolds without the crossover.
Tz750 intake manifolds P/N 409-13565-00 are discontinued but TZ Mike does make very good quality reproduction manifolds.
Racing Ignitions
-Motoplat
-PVL
-HPI Racing
-HPI also makes a small external rotor ignition with lighting (M in SC)
-ProFlo (No longer available)
-TZ250/350
-MZB
-MZB also makes a CDI ignition with lighting
-If you just want to eliminate your points which is ALWAYS an improvement Vintage Smoke makes a DYNA ignition kit that bolts right on. Like I always say "the problem with points is they start going bad the minute you put them on.."
RD400 Model Codes
USA Daytona Model code 2V0
Canadian Daytona model code 3J7
Oceana Daytona model code 3M4
76-78 model code 1A1 - all markets
'79 European model code 2R9
The cylinders and heads from a 1A1 will fit all years, as long as they are swapped as a complete set, along with the exhaust pipes. The cylinders, head and head gasket for the 2V0 are unique. The cylinders for the 3J7, 3M4 and 2R9 are the same. The 2R9 had separate cylinder heads and the 3J7 and 3M4 had a one piece head, they should be interchangeable. The 2R9 had separate head gaskets and the 3J7 and 3M4 had a one piece head gasket, but 2R9, 3J7 and 3M4 have the same gasket thickness, so you could use the separate gaskets on the Canadian and Oceana Daytonas.
TZR250's
1986-88 2MA - 1KT  Case reed forward facing cylinders
1989-90 3MA           Reverse Cylinder
Transmission Ratios
TZ250     RD400   RD250/350
.81            .888         .785
.87            .961         .888
.96            1.083       1.040
1.13          1.318       1.318
1.42          1.778       1.778
1.93          2.571       2.571
Primary Gears
RD250   68/21  3.238
RD350/400/LC/RZ  66/21  2.869
TZ250   77/23  3.35
TZ350   74/25  2.96
Cylinder Studs
RD 250 90116-08065-00  90mm(72-73mm sticks out of casing)
RD350 90116-08064-00  97mm (80-81mm sticks out of casing)
RD 400 90116-08232-00  117mm (98mm sticks out of casing)
TZ250  90116-08213-00  94mm
TZ350 90116-08212-00  101mm
TZ750 90116-08212-00  101mm
RD250LC/RD350LC 90116-08219-00  106mm
EE
#35
So I asked the guys on the RD LC crazy and RZ forums for a bit of input on LC to RZ differences and got a bit more input. This should be about it. Ed
Bear with me I went over the 20,000 character limit again!!!
Organicjedi
Quote from: EE on July 09, 2019, 05:22:35 PM
Probably the thing that has given me the most enjoyment over the years working on RD's is that on an average guys budget with hard work (lots of time, lots of thought, lots of more thought and lots of more hard work yes..) and the patient and persistent application of good science (and yes more hard work..) these bikes can very often just honestly do "more than their supposed to be able to do".... You gotta love em, don't let anybody tell you their not the race bred descendents of the RD56 like their racing cousins like I tell guys when their on the pipe they don't know their not TZ's!!! Gotta love em, all that rolled up in aircoooled simplicity.. No RD's are not CPI cylindered RZ/Banshee megabuck motors but dam can they perform with a lot of hard work and good science.. Ed
:good: YES!!!
EE
(From the 1970 DS7/R5 to the 1990 reverse cylinder TZ250)
(Note: for ease of reference I refer to 73-80 TZ's as "early TZ's")
1967 The YR1 Yamahas first horizontally split parallel twin (61x61 350 2 transfer piston port)
1970-1972  DS7/R5 start of the 4 transfer  port cyl base/case layout that form the basis for the RD and early TZ  series
DS7 / TD3  250
R5 / TR3    350
An interesting point: The some of the "works" TR3 engines from 1972 sported 6 transfer ports, like the 79/80 TZ350
1973-1980 TZ's used a variant of the "RD" cases but used Piston port monoblock watercooled cylinders
1980 the TZ250 G in a last ditch effort to get ever last hp out of the "RD" based case engines ran an intake so big it became know as the piston eater
1985 Yamaha again Redesigned the TZ250 engine. 1985-1987. Switching for the first time to case reed induction to create much needed bottom end and widen the powerband. BUT 1985's reedcages were to small and were quickly enlarged
1988-90 in a last ditch effort to get every last hp out of the parallel twin design Yamaha reversed the cylinders & tilted them forward to 60deg putting the carbs in front & the pipes coming straight out the back under the seat
Because the R5/DS7 was the first Yamaha to use the 4 transfer port cylinder base case layout (2 on each side with a 5th boost port added in the RD series) RD, LC and early TZ cylinders will bolt directly onto the R5/DS7/RD and LC cases.
BUT the R5/DS7 only had a 5 speed but it is super easy to swap out the gears, shift forks and shift drum for an RD 6 speed setup
TZ cases were a separate casting than RD cases, a very slight variant but still a separate casting, so close though in fact that when TZ racers  broke early TZ cases it was super common to replace them with RD cases
The grooves to locate the TZ crankshaft are cut into the crankshaft inner bearing area  instead of the primary side bearing area because the TZ's used a different crankshaft (that will interchange if you cut the grooves in RD cases) that used Roller bearing outer main bearings
The oil drain is in the middle of TZ cases but offset one the RD cases. The center RD crank bearing surfaces normally have a cast in steel insert buy the TZ cases normally don't BH
Early TZ's had a different transmission, though it can drop right in RD cases it has a VERY tall first gear and much closer gear ratios with a longer mainshaft to allow for the TZ dry clutch
A TZ dry clutch with a special mainshaft and slight modification for gasket sealing to the cases will bolt onto an RZ
Almost all DS7/R5 cases had no grooves in the crankshaft seal area to secure the seal as everything RD and later does but I'm told some did. And they did not have the mainshaft clutch side bearing retainer behind the clutch
RD400 cases have slight differences in the castings, the earliest had a little less material around the cylinder base gasket area at the rear and more ribbing around the right main bearing and right transmission mainshaft bearing in later cases.
Starting with Daytona in the US and later UK cases used a different kickstarter mechanism. Daytona could use either kickstart mechanism, I was told back in the day that the gear on the "Daytona style" kickstart mechanism which on this new design was not constantly engaged with the idler gear like the earlier mechanism, in racing had slid over and engaged on some racers so common practice was to retrofit the old system when using "Daytona' cases. I did have one customer that would not take no for an answer so I used a cut down throttle slide return spring to keep the kickstart gear positively disengaged when not in use. One drawback with the "Daytona" style kickstart mechanism is that it does kick over more slowly . This style also used a "single" offset idler/tach drive gear instead of the 2 gears pressed together of the earlier style.
EarlyTZ's used this "double gear" also but ran it with a needle bearing. Later RZ's used the "single" gear but added a bushing to it
Since Daytona and later RD's used the single gear kickstart idler gear they used a longer tach drive shaft, a smaller nylon tach drive gear  and a different tach drive ratio
While the rest of the world got electronic ignition in 79/80 the US didn't
The Daytona, got a new crankshaft without the dreaded lead weights but improper heat treating it's believed caused them to snap the center section under racing conditions
LC's went a step further and went to the now well know RZ/Banshee style crankshaft but the LC's still had a 16mm wide big end bearing (RZ widened to 17) with larger big end and wrist pin bearing outer diameters
An LC crankshaft will fit in Aircooled RD cases, but you need to mod the end of the crank, OR 'doghouse' the RH cover to take the longer crank. (no oil pump can be used after this mod) the LC crank also allows for a large taper cdi to be used, and yes, an RZ or LC cdi will then bolt right on to aircooled cases. you will need to clearance the LH cover to accommodate the cdi pickup though
An RZ crankshaft is aprox 2 mm too wide to drop right into RD/LC cases but have been made to fit.
RZ cylinders while will "slip in" to RD cases but have a much different cylinder base stud pattern, the cylinder center to center spacing and heights are the same as a RD and LC 350 they just won't bolt up
Some have used the wider RZ rods on RD cranks by machining .5mm off the inside of each crankweb
An RZ clutch cover will almost fit onto an RD set of cases but the RZ have a little more metal in two places Teazer
LC and RZ use the same kickstarter arrangement/mechanism. Similar to the Daytona and later UK RD's On the RZ/LC the inner end of the kickstarter shaft is a smaller diameter than RD's, so either the cases needs to be bushed or a sleeve pressed onto the shaft. The outer portion of the shaft is longer than an Air cooled motor which is fine if you use an LC or RZ clutch cover. This can only directly be done on Daytona and later UK cases as there is a different style locator spring boss in those cases (unless of course you weld and machine the cases)
Twice to use an LC side cover I grafted two early style RD kickstart shafts together to extend the kickstart mechanism the needed 17mm.
You can run RZ/Banshee primaries on an RD I've done it many times
76-78 US RD400's had a small cutout at the bottom of the skirt on the exhaust side for emissions reasons that actually let ex gasses into the crankcase at TDC The Daytona did not have this cutout because it used vacuum controlled external exhaust butterfly valves to accomplish the same result so the trick was to use Daytona pistons in all the 64-65mm bore RD's at least until RZ (and LC) pistons came out.
76-78 US Rd400's also came with an small exhaust bleed port in the roof of the exhaust port approximately 10mm above the port, in performance applications it's standard practice to plug and weld these closed
All year RD350's in the US had Dykes ring pistons (not good for racing)
An RD400 left side cover will fit an LC perfectly, you just have to make some room for the electronic ignition trigger for the LC Jspooner
The LC and RZ bottom ends are very similar
The crank width was the same from RD to LC but they did widen the trans gearset making the gears wider
The RZ crank width increased slightly (approx 2mm) and with it another increase in gearset width and shift drum. Gears differ but the RZ uses a few of the LC's gears I counted 3 with the LC 4L0 prefix, both changed to the "shiftstar" type gear change mechanism. LC and RZ crankcase mount dimensions are the same, but differ largely than the aircooled RDs. LC/RZ engines have 2 mounting points, aircooleds have 4. Aircooled RD's had a first gear needle roller bearing were the LC went to a bushing there Tacky/Dusty
LC/RZ use the same shift forks . Tach gear assemblies are the same LC and 83-84 and US 85 RZ . Clutch basket/ primary gears are interchangeable. Clutch hub ,  LC clutch cover will fit the RZ , same gasket for both . Oil pump are interchangeable , 1979-80 RD400 2R9 , LC and RZ . Coolant pump , LC and RZ . Reed valves , RD350 , RD400 and LC plus RZ500 . Carburetor manifold and balance tube ,1979-80 RD400 2R9 and LC . Motor mounts with spacers , LC and RZ  and stays under the motor to the frame  Zedixie13
RD250/350B.  Euro 521/522 models have 521 cylinder heads and gearbox. The gearbox has all 6 speeds available and has the same ratio's of the later 250/400 with overall closer ratio's
RD250/400C/D.  Euro 1A2 (250) and 1A3 (400).  Similar to 1A1.  Gearbox shafts have later type splines.  Cylinder heads are marked 1A0 (250) and 1A3 (400), different casting to 1A1
RD250/400E.  2R8/2R9.  "TZ" style crank with no lead weights and slotted rods.  Revised cylinders, porting and CR. Revised 400 pistons without front cut-out in skirt.  CDI ignition. Revised LHS case cover with bulge over CDI pick-up coil.  Gearbox and shifter changes.  Narrow primary gears.  Small "LC" X-over tube on 400.    5Port
Banshees had different transmission gear ratios than the RZ most everything else interchanges between the two
RZ350 or Banshee pistons are a far superior piston than the stock RD pistons.
1980 IT/DT 175 pistons or Yamaha Blaster Pistons. Either piston is 5-6mm shorter than stock and requires machining the top & bottom of the cylinder to compensate for the height. The blaster pistons also have a 10deg piston dome instead of the RD/RZ/IT/DT 15deg so it does require reccutting the cylinder heads (but if your doing a bigbore you need to recut the cylinder heads anyway)
There have been some Extra Big Big Bore cylinders done with H2 pistons and sleeves. JR
The Crankshaft
Big End Bearings
A newer option though is to use Blaster exhaust flange gaskets Supertune
RZ350/Banshee Clutch Basket and Primary Gears fit right on to Rd's
TZ250/350.(Takes a little work) Use the clutch and primary sidecover. This requires a longer mainshaft, but the stock TZ mainshaft has a higher first gear than the RD's and is part of the main shaft so you can either run the TZ transmission with higher first gear and close ratios or get a special mainshaft from this company: http://www.yamaha-tz-classicracing.de/uk/teile_getriebe.html that allows you to use an RD transmission with the TZ dry clutch parts. The TZ dryclutch cover didn't come with a provision for a kickstart mechanism but I have seen several of these covers modified to use a kickstarter. I've used a billet LC cover by Metemachex to do this with a kickstarter but you have to extend the kickstart shaft 17mm. NOW Fondseca makes a dryclutch cover with the kickstart provision
Transmission
Reeds and Reed Cages our options are:
Use the stock reedcage with a single petal reed from TDR or 93-2012 YZ85 reeds trimmed down just slightly at the front. These are a single petal reed but thinner than the TDR petals Or
Modify your stock reedcages by removing the center divider and using single petal reeds, this works great for 80% of the RD's out there,
If your extensively modifying your stock reedcages ask for the Harry Barlow cut it's a tapered reed that completely covers the reedcage surface area
Stock YZ85 reedcages
V-Force YZ85 reedcages. Part number V382A (Use AG472A stuffers) Afhaldeman
RZ350 reedcages
RZ350/Banshee V-force reed cages
My favorite for 90 percent of RD applications is stock YZ85 reedcages with either stock reeds or TDR racing reeds part# 88-EE or V-force YZ85 reedcages.
Intake manifolds
Racing Ignitions
Motoplat
PVL
HPI Racing
TZ250/350
MZB
RD400 Model Codes
TZR250's
Transmission Ratios
.81            .888         .785
.87            .961         .888
.96            1.083       1.040
1.13          1.318       1.318
1.42          1.778       1.778
1.93          2.571       2.571
Primary Gears
RD250   68/21  3.238
TZ250   77/23  3.35
TZ350   74/25  2.96
Cylinder Studs
Gill
Thanks Ed, Its a comprehensive post, shall bookmark it for reference.
EE
Hey Guys This collection of information was a bit o work so to make sure the information doesn't get lost and stays easily accessible I put it up on my website so it's there if you need it, I keep adding to it too.. http://erlenbachracing.co/RD_TZ_LC_RZ_history_and_differences.htm
Ed
Plasticman
I turned this into a WORD file, if anyone's interested.
Rob
1976 - RD400 - road racer
Great information; I thought I was seeing things in the barn, but the RD350LC shift drum IS shorter than the RZ/Banshee item, and for a reason. Thanks EE  :like:
irk_miller
Yamaha 90116-08232 works for the RD to LC cylinder studs. They're 116mm long, but come in way cheaper and they're common for US buyers ($6 ea). They cross reference with Banshee, RZ350, RZ250, RD (all), XS650, XS1, XS2, R5, R5B, R5C, TD3, RT360, DS7, TX750, TX650, TZ750, YZ80, YZ60
This is a wonderful thread, and I thank you guys for putting it together.
2t Fan
Primary ratio RD350/400/LC/RZ  66/21  2.869....its 66/23 right ?
Quote from: 2t Fan on October 20, 2021, 12:34:50 PM
Yes, the "21" is probably just a typo. The listed ratio is correct, 2.870 (rounded)
List of primary gears:
19T  RD60, RD125
16T  RD200
21T  DS7, RD250
23T  R5, RD350, RD400, RD350LC, RZ350
