YPVS Loses Position(?)
I wish it was like an episode of house. we would have been done in an hour then had time for donuts 🍩  😅
Quote from: 2steve on December 09, 2025, 07:31:58 PMI did measure them to compare with higher quality calipers.
They were really close to each other at the tip, midway and near the top, plus overall length.
That still doesn't explain why I'm running the highway or interstate in the good rpm range and it slowly winds down to a crawl or completely stops
If it does come to a stop, it will kick back to life like nothing happened. This behavior started the bowls-running-dry theory that has been disproven and appears electrical in nature.
That particular symptom sounds exactly like a partially blocked air vent in the filler cap. Bowls run dry and when the bike stops, enough air gets in to allow fuel to flow.
RDnuTZ
yep, I thought vapor lock too, and it's easy enough to check (on dirt bikes at least) by removing rubber gasket and locating breather hole in the cap and blowing compressed air through it. Had a couple plugged holes in my lifetime. Only other thing that mimics the "runs for a while, shuts down, and starts up easily again" is an ignition coil that goes open circuit winding when hot, but cools down, closes the circuit and starts again. Mark has tons more experience in this stuff than me so I expect he'll solve it soon enough.
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
that too has been tested, i thought the same thing.
2steve
There is a brand new coil on it. Had never taken it for a long enough ride with the old coil to compare the shut down symptom. So, there's that.
https://www.economycycle.com/product/1984-1985-rz350-usa-wiring-harness-48h-82590-50-00-reproduction-harness/
I am generally critical of firing the parts cannon at a problem, but $150 to replace 40 year-old wiring seems like a reasonable step. I surely have an extra harness you could borrow for testing, but once you've paid to ship it across the country twice and gone to the trouble of swapping it out, you could have supple new wires and clean connections and eliminated a possible cause.
2steve
I agree, Wade.
And maybe the new coil is part of the problem(s). I have the original to try out on the highway. Separate issue?
John has a plug kit for the aftermarket Zeel to plug into the original harness. So that, along with his harness, is a serious consideration that I'll likely go with.
Then there is the offer from Mark and Marc to help with carbs.
I'll be working thru it all in the usual throw everything at it so when it runs right, I don't know exactly why.
The parts cannon has been a problem so far, and it usually is.
Still thinking about the previous reminder that I changed a rough looking needle to a new Toomey. The reason was because the carbs wouldn't act like they were synch'd but not because it wouldn't really run well. That was probably the left side float difference.
automan
I thought you were to put it back to stock, or when it ran good then go from there?
2steve
It was stock, other than Toomeys with Toomey jetting. Any changes that were made were to overcome the new poor low rpm running problem.
The new Toomey replacement needle could be suspect and the new Yambits coil could be suspect of the other possibly-newer separate problem.
It's still a mystery and now it's harder to cuddle up with it in the garage and test ride.
Last I looked at the carbs after the visit with Mark, (using his correct point of view to check from the cylinder side instead of the filter side), the right carb really is different in slide stroke. Changed it to be equal to the left at lift off. Now wide open is unmatched.
Didn't fix it down low though.
we checked it.. they are even . but this is the last thing that was touched, hence why id like to eliminate it as a possibility
While you are loading up the parts cannon, I wasn't sure if it dies suddenly like hitting the kill switch or it just sort of dies away like running out of fuel. The first suggests an electrical issue and the latter, fueling. And IIRC, there was an issue at part throttle/low to mid revs that clear up at higher revs.  That would suggest PV timing, pipe resonance or needle portion of the fuel map. If it feels more like it is tightening up and then frees up it could be too much advance at those revs.
Just thinking out loud again, which is always dangerous.
2steve
It smoothly ramps down on power, leaving time to find a place to either pull over or let off the throttle hoping that it will come back some before it completely dies. First time, I was sure it must be seizing. Crapped my pants.
It does not lurch like it's running out of fuel. Mark did a flow test on the tank/cap/petcock and the needles+seats are new.
I somewhat suspect the new Yambits RZ350 coil on this. There will be testing with that against the old coil - which was probably working just fine but became a victim of the parts cannon BEFORE this highway die-out situation came to light.
Also, I have switched from the new Toomey needle to the old, chewed up Toomey needle - mentioned in the very first post - and you pointed that out, teazer.
Figured out how to change the needle without removing the carbs. Fiddly but can be done.
Test ride is pending on that. Maybe Sunday with the 64 degree F high.
I'm not confident. Hopeful though.
holding the throttle when i rode it at 1/4 , 1/2 and 3/4-wide open yielded the same results (flat almost dying ) ,  between like 3k and 7 k, then it takes off.  mind you i didn't ride it much but it was VERY VERY noticeable .
automan
Loose or cracked reed?
broken intake skirt?
steve said the reeds were good, intakes looked great
