RD350 POD INSANITY!!
Started by SmokeAddicted, December 24, 2025, 01:14:50 PM
SmokeAddicted
I recently acquired a 73 RD350 with a few upgrades. One of which is PWK 28mm carbs with reed block spacers. This leaves me with seemingly one option for decent pod filters (pictured) before running into significant frame contact.
The bike came with universal 3" Uni Pod filters, with a rubber backplate. I've spent days trying to find the same filter, without a back plate. No luck whatsoever.
I'd love to run a Y-Boot, but I don't see how that can work, nor am I aware of any option that's not completely custom made. OEM doesn't seem to be an option.
If I rotate the filter inwards, this is the only thing I thinking MIGHT work. Uni 4" angled filter
-Does anyone have a pod filter suggestion that will work here?
-Is there a Y-Boot out there that will work for this application? Something that isn't completely custom made.
Inlet bell size is 50mm
 :help:
**1973 RD350
**421 Banshee Motorcycle Project
**2020 Beta 300RR
**2022 KTM 500 XCF-W
Is the little bit of contact hurting anything? Asides from the aesthetics?
On my 73 RD350 with an RZ / Banshee 421 stuffed in theres i have billit intakes to lift the TM34 carbs up to clear the cases. this leaves even less spavce for the filters, so I went with a twin filter sock that just fits over the carbs tight enough to stay in place
SmokeAddicted
Quote from: sav0r (CL MotoTech) on December 24, 2025, 01:43:58 PMIs the little bit of contact hurting anything? Asides from the aesthetics?
No sir. That doesn't bother me at all. My desire to run a filter without a rubber backplate is the reason I'm searching. I can't find one that's the same length as the one I'm using (3"). The shortest I can find is 4" and create further clutter.
I am under the impression that a pod with a back plate is less than ideal, and potentially affecting fuel delivery by pressure reflection vs dispersion.
**1973 RD350
**2020 Beta 300RR
SmokeAddicted
Quote from: rodneya on December 24, 2025, 03:10:25 PMOn my 73 RD350 with an RZ / Banshee 421 stuffed in theres i have billit intakes to lift the TM34 carbs up to clear the cases. this leaves even less spavce for the filters, so I went with a twin filter sock that just fits over the carbs tight enough to stay in place
That's interesting. I would have assumed it would fly off in a hurry. Something to consider. Thanks!
**1973 RD350
**2020 Beta 300RR
get the 15mm angled all foam ones and angle them in. the link you had, those,. but get them longer, 5" will fit. slide the outer red sock off though.
the ram air is a great way to go as well.  :bacon:
Brad-Man
You could try soaking a y boot in a 50/50 mixture of wintergreen oil and either xylene or acetone overnight, then putting the PWK's into the openings and let it dry out...
1974 RD350
1975 RD350/400 project
1985 BMW K100RS
SmokeAddicted
Quote from: m in sc on December 24, 2025, 04:47:08 PMget the 15mm angled all foam ones and angle them in. the link you had, those,. but get them longer, 5" will fit. slide the outer red sock off though.
Wow! I never would have considered trying 5". Mainly because I didn't think it would fit. Guess that's what I get for not measuring.
 I guess a longer intake track that's smooshed together is better than a shorter one that's less smooshed. I appreciate the response. Will likely go this route.   :metal:
**1973 RD350
**2020 Beta 300RR
SmokeAddicted
Quote from: Brad-Man on December 24, 2025, 05:50:52 PMYou could try soaking a y boot in a 50/50 mixture of wintergreen oil and either xylene or acetone overnight, then putting the PWK's into the openings and let it dry out...
That's a thought. Seems like it could become a pain in the butt to re-jet afterwards. I have a buddy with a crispy Y-boot that I'm sure he'll give to me. Worth a shot.
**1973 RD350
**2020 Beta 300RR
SmokeAddicted
#10
Quote from: m in sc on December 24, 2025, 08:10:46 PMyou can get adapters for the y boot to fit. however, there's not much improvement over unis on this setup  but its pretty good. I actually have a set of these,  they transition nicely.  https://www.ebay.com/itm/205329844408?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D264184%2C297274%26meid%3Db0e71567ab474e98989f2f06e67aee94%26pid%3D101430%26rk%3D1%26rkt%3D12%26sd%3D145136669534%26itm%3D205329844408%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A205329844408b0e71567ab474e98989f2f06e67aee94%7Cenc%3AAQAKAAABMDJfxvEKz%252FWsdyy97PIVwAhtkTIJPGKp%252Bu7TYjjsvNO4eN9duTRR%252FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%252B5fAXiG4ymw5%252BD4QiZh5nLn8OmQxsMtW2i8ZUV2pH7rpMHom3tehwcYL74GdskUTIs7%252BsNJe88EaLSRtkkqVA%252BkGhl2iLiCQB9v2SDbCmWXDM138yOcU4PGV9cmIfVPYtDanhBqbvm1cYVWjUy79xVGBqasqT%252B06FVf6RpStTUX5knfyPthf7aHc3jETcSsaf3MYAZCqb%252F4Xb5CiIudSl%252FFC%252BdwwC9w8t18fenoAcBYAFuPCH1ChJVwjeUq2ff1mztyOH22my6e6gZKuQCEoPb%252BCalLgLap8bRaMVWVOKd57irU%253D%7Campid%3APL_CLK%7Cclp%3A2332490&itmmeta=01KD9H0WYT7FX8627R02V9PHPQ
The more I dive into the interwebs, it seems the difference between pods and Y-Boot on my street machine, is nominal. A Y-Boot would be more desirable in a race application. Would you agree?
Thanks for the responses. You're all over this forum and clearly know your stuff. Merry Christmas
**1973 RD350
**2020 Beta 300RR
actually either  . i run a y boot on the r5 w rd motor, its great.
SmokeAddicted
Aweso
Quote from: quocle603 on December 26, 2025, 10:26:07 AM
Yep. Currently running this on my pwk28 set up. Runs great!
me
Quote from: quocle603<br> link=msg=61676 date=1766762767
I'll have to give it a shot. I reviewed the jetting table and there was very little (if any) data around jetting a PWK with a Y-Boot. Do you have a rough foundation of where to start with jetting the Y-boot?
Current jetting is very fat and I assume I'll need to lean it out with a Y-boot.
**1973 RD350
**2020 Beta 300RR
38-42 pilot
jjh needle middle
142-150 main
should get you close
