67c2tr upgrades /cdi
Started by m in sc, December 12, 2025, 11:41:07 PM
Little ripper! What's the rough temp down there?
today in the middle 50s. I rode to work today.  yesterday about the same. did a small group ride for NYD.
finally got the new rotor for the CDI from Vape, John at Economy was a huge help
and its good, only thing i had to do was trim back the ignition winding base a few mm to clear the rotor. (its just plastic but you have to be careful)
Bike was dead cold, hadn't started in a few days (in the vid).
used a piston stop after motor was set to 1.7mm btdc, then put a bungee on the kick starter to hold it in position. was pretty easy
NOTE: the rotor that worked was a A70R-94  THE '92'  is the ke100 one that i had to use the taper on. that '94' rotor needs to be asked for as i dont think its on the website directory
RDnuTZ
great work  :thumbs: Looks like there's a little groove in case ahead of the CS sprocket- is that manufactured that way or chain wear from a previous owner?
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
Simmons1
Very cool.
I wish I had half of your mechanical skills and know how.
Quote from: RDnuTZ on January 13, 2026, 09:32:26 AMgreat work  :thumbs: Looks like there's a little groove in case ahead of the CS sprocket- is that manufactured that way or chain wear from a previous owner?
its made that way.  the next year or 2 had a hi lo range, and that casting was open and integral to that. however in early 67, they hadn't implemented it yet, so thats why it has the weird dual rear sprocket.  its a really odd bike. and thanks, I was determined to update the electrics for years
then there was this..  :undecided:  :dawg: had the go pro running so .. the stud pulled and headgasket went kaplowie.  luckily no real damage.
RDnuTZ
bummer. Stud just back out a couple turns or actually strip portion of itself and/or threads in cylinder?
threads in cyl gave up.  repaired that last night, installing now.  I mean, thats all part of it.  :devil:
heres the video.
Doh! Glad it was an easy fix with no other damage than the threads & gasket.
