I don't want to kill my gas can anymore
Started by 85RZwade, October 25, 2026, 08:19:48 PM
I have three gas cans, with three different spouts ranging from not too bad to is-this-a-psychotic-episode? I'm sure others have come up with this, but I did hatch this idea my own self: a tire valve stem employed as a vent. I had seen a stem installer like this somewhere along the line:
I bought one on eBay (a story of its own) and drilled a 7/16" hole about where a vent would have been in 1975 and pushed the tool in, through the handle and to the spout opening. I screwed on a valve stem and pulled it through; things got a little bound up at this point, and I had to make a tool from a cheap old screwdriver.
A little gentle persuasion got everything where it needed to be, and a good yank seated the stem (now known as a VENT).
I removed the core from the stem and put a cap on it; I'll let you know how it pours when I get the the gas station (loan approval pending).
Update: complete failure. I found all three stems on the floor of my garage, broken at the neck.
 :confusing2:
RustyRD
 :eek: ok , so what can we us as a base for a hose now?  metal valve stem ? These new style gas cans drive me crazy.
RustyRD
#3
quick search (gas can vent) found some items that may provide some ideas. this pic was from an eBay add, 3 for $10
RDnuTZ
I'm a little slow here, but I guess I missed the driver for adding a vent after the fact... is it to smooth flow when pouring from the spout? Or keeping cans from contracting/expanding when stored in the shop? Or something else?
1977 RD400 (Project)
1974 RD350 (2) (Projects)
1973 RD250 (Project)
I was trying to improve flow when pouring; these unvented cans pour slowly!
After my "improvement", they poured smoothly and quickly...once. I'll be looking for the brass ones on eBay today.
RDnuTZ
I see, said the blind man. I pride myself on being a Luddite and would not have envisioned your elegant solution  :devil:
I think I would have done it Primitive Pete style using a cheap inline fuel petcock with a gromet in the hole in the tank and open the tap to vent  :dawg:
https://www.walmart.com/ip/8mm-In-Line-Petrol-On-Off-Fuel-Tap-Switch-Valve-Motorcycle-Bike-ATV/10928661504?
Yamanatic
A few years ago I bought a self-venting pour spout off eBay - works like a charm.
WW
RDnuTZ
the brass kit Rusty posted looks good :thumbs: I'm still trying to figure out how you fish the stem through the hole from the inside?  :umm:
Quote from: RDnuTZ on November 13, 2026, 12:24:48 PMthe brass kit Rusty posted looks good :thumbs: I'm still trying to figure out how you fish the stem through the hole from the inside?  :umm:
It does, BUT it comes with a 5/16" drill and the holes in my cans are 7/16"; no bueno. They could be pulled into place with the tool I wrote about above, or guided with a piece of stiff wire, as they don't need to be pulled into place with any force.
RustyRD
I saw a video where they used a thin piece of wire to push from drilled vent location to fill location, bend end of wire and pull into vent location hole drilled earlier.
2steve
Smooth, controllable pour, doesn't leak (unless you slam and break the black plastic elbow at the bottom).
You can bring the flexible hose up and cap it so it doesn't drip afterwards.
Survives temp changes ok so far after 5 - 6 years.
"Surecan 2 gallon"
https://ebay.io/m/WjY9vU
or:
https://tuffjug.com/products/5-gallon-jug
as far as pulling it thru, use a stem pulling wire tool or tape it to a straightened section of wire, then and fish it thru.
