Oil Injection Nipples
Started by motodreams, September 17, 2019, 10:59:28 AM
motodreams
Hello!
I am after a single oil injection nipple that goes into the carb body.
Where can these be purchased or does anyone have a spare?
Thanks!
2steve
Wondering if the new ones will fit tighter. Had to zip tie mine in place. Occasionally, I find them working their way out of the carbs - scary.
I need a couple of these for my PWKs.
Would much prefer they were aluminum not plastic.
Was planning on gluing them in with JB or something.
motodreams
Hmmm,
Wonder if there is somewhere else that sells them.  Not really into being charged $13 shipping on a $7.5 item.  Could ship this for a buck.
Anyone have a spare around for a tenner delivered?
Economy Cycle John
we could ship you one first class mail if you call the order in and ask. or we have them on ebay below. Our shipping on the website is flat rate so for most orders works out to the customer's advantage.
https://www.ebay.com/itm/123726816521
I've actually designed this part with my 3D printer. Just need to get the brass part for it.
Djg8493
Quote from: quocle603 on September 19, 2019, 07:45:18 AM
It would be really cool to have a 3d print version designed as a plug for people running premix :umm:  Unfortunately I do not have those design capabilities.  I know you can tap it and put a bolt in etc but it would be nice to have something that you could go back to the pump if you choose to.
you can just use a vacuum cap on the stock nipple. or, just connect the 2 carbs with a vacuum line between them.  ive done it, its fine, doesn't affect running whatsoever.
Djg8493
Quote from: m in sc on September 19, 2019, 09:49:39 AM
Thanks, yes I have the vacuum caps on there now, was just thinking it would be a cleaner look.  Ironically I even work for the company that makes most of the vacuum caps for the auto industry:)  I might try connecting them, never thought of that
cool. where can i get some that wont disintegrate after a year or 2?  :dawg:
Djg8493
Quote from: m in sc on September 19, 2019, 11:07:03 AM
Fair point, not from us...  Trust me I have made that complaint to the product manager.  Retailers want the costs too low.
no prob. lol. i usually use vac hose and machine a plug for it, ive given up on the caps these day.
Quote from: 2steve on September 17, 2019, 01:26:16 PM
When using the stock nipples... take them out, lay on the steel pad of the vise, just the tube,  hit them with a small steel hammer to oval them just a little, then brake clean and loctite in with green sleeve retainer 640. Go slow with tapping them back in, don't want to break the plastic.
For those that want to go premix, tap hole and use a phillips ss machine screw with some Yambond or Motoseal. I have to look at the shop to see the screw size. No drilling the hole, if you want to go back to nipples... heat screw with a hair dryer, remove, clean with lacquer thinner and then use the above method to re-install factory nipples.
No drama or failures using these tips and tricks ...
