RD400 under construction
Started by rd400greenhorn, February 16, 2019, 02:25:29 PM
GT750 are fun bikes.  They are just a little bit heavy and underpowered stock but that can be changed without spending a fortune.
rd400greenhorn
Yet another small update
Chuck aka supertune sent me a Quick Throttle and cables for the Tm34 carbs
Works very Nice
Got the New gribs on as well and everything is tight and Looking good.
rd400greenhorn
A little custom bling for the build
8)
Cool to see a little more progress!
I like that adjuster cover... :celebrate:
rd400greenhorn
Thanks chuck :patriot:
Allright, Another small but good update
1 issue solved, i took the clucht out and the kickstart mechanism, Saw the First shim that goes on the shaft was to big ( having issues with it not popping back up when i kick it)
I found the correct shim, put it All together and it works as intended.  :toot:
Another one that had been irretating me, was the fact that my clip ons hit the gas tank on Both sides when turned, but a good idea from this forum, and now i Drilled a 4mm hole in each steering stop on the lower tree, put a 4mm bolt in with a narrow head? And it works perfect, without destroying the tuning radius. Looks fine to me.
So Thank you for the good simple idea 👌
Next i Will properly address the tdc
Any tips/ etc on how to do this would be appreciated. I do have a measuring clock? That goes in spark plug hole
Plus i am Also using Electronic ignition, but having never done Any of this before, Please do Come with advice  :vroom:
Shop for a Central Tools Timing gauge #278 (old #) or Central Tools 6491A Motorcycle Timing Gauge (new #)
https://www.ebay.com/itm/Central-Tools-6491A-Motorcycle-Timing-Gauge-1-1-2-2-3-16-Contacts-01mm/163783679608?epid=1628125008&hash=item2622449e78:g:fEQAAOSw301dMeOp
List what ignition you have.
rd400greenhorn
Hi chuck
I already have a timing gauge, measuring in mm
Hopefully it works..
The Electronic ignition i have is a power dynamo..
rd400greenhorn
A small update.
Brembo brake fluid resovoir. Same in front as in back
rd400greenhorn
Hi guys!
Long due, but iam pleased to say that the project is Very much alive!!
Not much have been done, until the last 3 weeks.
I FINALLY found a guy willing and skilled enough to take on my seat/rear cowling and Electronic box.
I had a specific idea to how i wanted it to flow with the cofffin tank, and by the pictures, it looks like he is doing a great job. I Will have the bike back next Friday the latest. Cant wait
Since last
- Had the engine cover on the ignition side, welded some cracks and powdercoated to match
- My bike is currently at the metal fab. Guy, Hes had it about 2 weeks.
-mounted the clutch actuator in the engine cover ( bought for a yamaha xs400) but I think it Will work.
When the bike returns, i need to address
- complete wiring of the bike ( advice /tips are welcome)
Iam connections with a moto gadget M unit, so Its a completely new harness
- The ignition timing needs to be set. This i never tried and Will rely om chucks guidance
Stay tuned people💪
rd400greenhorn
rd400greenhorn
Fabrication...
rd400greenhorn
The rear light is a husqvarna svartpilen 401, LED. Flipped up side down 😁💪
rd400greenhorn
The sheet metal work is made in 1,5 mm stainless steel
Hope you Guys like it, the project is closer then ever to completion😁💪
rd400greenhorn
Profile rear
I like it, looks great. Your project is getting close!
Where are you, Greenhorn?
