'How To' Yamaha oil pump testing
Started by SUPERTUNE, October 24, 2019, 08:43:37 AM
Arrow
The cams can be worn out if specification, but drastically different rates of wear on the two lobes is quite rare. More like a sticking condition for some reason.
so-cal-sdr200
I wonder if I could push the pump by hand
on the short stroke?
Need another guy, or, a third hand.
One to hold the drill, one to hold the throttle and
one to push the pump piston.
Or take it apart for inspection...
Thank you again.
Arrow
#17
Sure, take the nut off and the large washer. Turn the shaft by hand. Gives you more time to see whats going on. Please report back, does it stay in or spring back?
so-cal-sdr200
Yes. It seems to be sticking on every other stroke.
On the short stroke, I can push it in / down with my fingers.
This is with the throttle plate turned to max.
The stroke does not feel smooth.
I assume on the down ( pump ) stroke I should be able to
cycle the shaft in and out freely.?
I am guessing at idle, up to maybe 1/2 throttle the pumping
should be roughly equal. Am I of the right mind?
Guess it's got to come apart.
EBay has a NOS one for $300!!! Yikes.
I'll get back in a day or two.
Cheers, Jeff
Arrow
Yes, and;
Should be equal at all throttle settings.
Most unusual how there is so much difference in 180°.
My work is never done......
Arrow
#20
I'll be honest with you, I don't see issues like this after pump builds. All the parts are reworked and inspected/measured. The pumps are built like a mathematical formula, always the same. Formula's are always the same, unless changed. Once we have the same formula, and measured values within specification, the end result is always the same. Only if the formula is changed or a measured value out of spec. is the end result different.
2+2=4, Always.
so-cal-sdr200
Thanks.
I want to apologize to Chuck for hi-jacking his thread.
Was not my intent.
I will create a new post for any follow ups.
Arrow, you did not rebuild my pump, so no fault of yours.
I am curious what the issue is and anxious to learn the inner
workings of these things.
As a retired aerospace engineering designer I guess it is in my
nature to dissect problems and figure out solutions.
  :vroom: on....
Arrow
#22
Correct, I didn't build your pump. Chuck won't mind useful dialogue, I'm sure. All helps.
I'm in Aerospace myself. For now anyway.
Covid has caused many issues for us. Might loose my job shortly......
JB Weld
Quote from: Arrow on September 09, 2020, 10:07:41 PM
Why not just use the genuine Yamaha gasket?
Perfect every time.
My only guess is that in 2015 when I rebuilt the pump, I was unaware of a factory gasket being available. I think I got the rebuild kit through Economy, or I piece-mealed it with information from others experiences online. I remember reading that originally Yamaha stated these weren't serviceable, so made sense the housing gasket wasn't oem.
Arrow
I seem to remember that originally the oil pump parts were on a seperate fiche only for main dealers use, and for the dealers to carry out the work themselves.
