Off to paint
Started by paul1478, December 03, 2019, 09:08:43 AM
My original graphics guy that did my Yellow screamer the first time 16 years ago moved to canada and sold his plotter So my other long time graphics guy did a remake in much more modern materials and Pauls job is the ginny pig other than the first guy was a dope!
They will be for sale soon as he's also making the one for the '78 seat tail cowl.
Then on to making them for the RD350 and the Daytona Special hopefully in the summer.
sweet, i thought that looked familiar.  :toot:
These new ones have the Yamaha tuning fork and some special black highlighting...(pinstriping)
I got my pained tank back yesterday. Looks good not perfect two small defects but I've had enough waiting. Put everything back together rinsed out the gas tank Put fresh gas in two-stroke oil in it and started up for the first time in five months.
Rode around the neighborhood. It ran well So I took it out for a nice little ride.
40 miles into the ride I noticed a little decrease in power and then the motor locked up. I was able to pull over put the bike in neutral and try to start it again. Kickstarter would not budge. I had to call my wife to bring my truck and ramps and some straps.
When I got home I pulled out the spark plugs. And this is what the one on the left side look like. something must've been in the tank or something must've been plugged in the carburetor. I was just cruising in about 5000 RPMs. So bad news I need to top end. But the good news is I get to go visit my buddy Chuck. I want to get it down to them as soon as possible so he can work on it and have it ready before deals gap. If anybody can figure out why it blew up it would be him.
did you bleed your pump and lines upon initial start up?
No I'm on pre-mix. I mix 40 to 1 like I always do the same container fresh gas good suggestion though.  Something changed from when I wrote it last and put it back together that's for darn sure
Bummer! I'd pull the petcock to see if there was any debris in the fuel...
Yes. I will and empty the tank again. I'm heading Down to Clearwater Thursday with the bike so MR Supertune can see what caused it and fix it. My wife says it is cursed. Last year was the power dynamo blowing up and now the top end.
Pull the fuel line off the left carb and check flow before taking anything apart. I see you have inline filters on the carb lines. These filters get blocked quite easily, thats why a lot of guys refuse to run them.
Bummer.
Just cruising along, my guess would be an air leak somewhere on the side that shows damage.
The other plug looks good?
Quote from: pdxjim on March 27, 2020, 02:53:54 PM
Bummer.
Yes. It looks a little black if anything.
Good idea. I'll check.
Hate to read that Paul but confident you and Chuck will figure out the root cause and get it repaired quickly.
Detonation for sure, but at 5,000 cruising the main jet is not really in play.  There may be a blockage or timing issue, but ask Chuck to check needle jets and needles.  That's where most two strokes fail on the street.
Rarely a main jet problem - usually needle and needle jet.
