Can this headlight be disassembled?
Started by rd400canuck, December 28, 2019, 04:26:21 PM
rd400canuck
Hey guys,
Went to look to see what sort of bulb my RD400c was running so I could order an LED replacement and i think the entire lens is the headlight, bulb included.
Can these things be taken apart so I can replace the bulb with an LED replacement?
RdsOnly
Sealed beam, NO not easily. Will brake the glass undoing seal.
Their are Honda sealed beams that can work, they don't have the spring tabs for adjustment screw.
The size is what you search, then the wattage.
JT
It is easier and cheaper to go with the after market bucket from Economy Cycle. It is an Emgo and then you have to do is order the bulb.
rd400canuck
I was just about to pop in and say I found that on Economy...
I'll order one up.
Thanks guys!
https://www.rzrd500.com/phpBB3/viewtopic.php?t=16259
Another interesting option ...
Honda VT 500 or 750 headlight assembly that he says fits 73-75 RD350.
Use the stock bucket and that assembly with the fanless bulb ... Worth checking out.
Honda 33120-MF5-751
But you are looking for a 400 so I don't know if this will work?
https://www.partzilla.com/product/honda/33120-MF5-751
rd400canuck
I think for the price I'll take my chances with the chrome bucket light assy from econo. I'm hoping it looks stock and is of decent quality.
RdsOnly
Economy light is much brighter- better than stock.
JT
Quote from: rd400canuck on December 28, 2019, 04:26:21 PM
Hey guys,
Do you have the stock alternator, or an aftermarket PMA/CDI unit?  If you have a Powerdynamo/Vape setup, you have plenty of power, even for a 80/100W H4 bulb.
rd400canuck
I'll be running an HPI unit. 60 watts apparently so LED's front and back.
you can run a 35w halogen H4 as well. just an option. The lumen output is close to a 55w H4 :twocents:
Quote from: m in sc on January 02, 2020, 11:44:31 AM
That's what I have in my RD plenty bright enough.
rd400canuck
Thanks for all the tips, guys.
Does it make sense to just go with low draw LED's so the coil and r/r arent taxed as much?   Or am I thinking too much?  :eek:
I see no downside in going with led. It's much brighter than the 35w I was uding with less draw.
true. you could go either way. just changing the taillight bulb and gauge lights will yield great results. the headlight bulb will help even more.
