clutch springs on tuned engine rd400
Started by rd400greenhorn, January 03, 2020, 11:31:25 AM
rd400greenhorn
Hi guys
I have mounted stiffer ? clutch springs and the question is, do I go with that or do i 50/50 with normal springs?
Still ongoing project but my motor is tuned with pipes, 34mm carbs, etc
And its going on the road this summer :)
check if the springs are the same as the manual recomm. if not, then get new ones that are 10%-15% more stiffer if you want to upgrade.
You can change all, or every second spring. Depended how much a stiffer clutch lever will bother you
